ltpitt
Fri Apr 04, 2014 9:36 am
Good day everyone!
I am happily using Aoe Initiator to mount a coraid unit on a Windows 2003 Server.
Lately I get a few errors from my qnap backupping on the coraid it suggests to chkdsk the target unit.
I've simply tried to perform a chkdsk of the o: unit mounted by Aoe Initiator but it always hangs up (never gets past phase 1 beginning).
Am I doing something wrong?
Maybe I need a special tool or different way to chkdsk the coraid?
Thanks for your time and patience.
Fri Apr 04, 2014 1:16 pm
It should work the way you do now! How long does it happen to "hang"?
ltpitt
Fri Apr 04, 2014 6:56 pm
It gets fast to "phase 1" and starts the counter
Then the counter stops to the same number for like...
20 minutes? Then I stopped it because I thought it was too long...
Is this normal?
ltpitt on Fri Apr 04, 2014 7:10 pm, edited 1 time in total.
ltpitt
Tue Apr 08, 2014 10:36 am
Hi!
Looking closer at your configuration we came to conclusion that you are running our software on unsupported version of Windows since it reached its EOL. You can always doublecheck with our system requirements by using this link:
www.starwindsoftware.com/system-requirements
I hope that helped.
