StarWind iSCSI SAN
Connecting to EqualLogic with Starwind Starport Initiator
Initiator (iSCSI, FCoE, AoE, iSER and NVMe over Fabrics)
Postby wauters » Thu Jun 14, 2012 1:10 pm
We have a working iSCSI SAN, an EquallLogic, which runs fine with the Microsoft iSCSI initiator.
With the Starport Initiator, we can't even connect. There's no login needed, neither local nor LDAP.
Any ideas?
The log is attached.
wauters
Re: Connecting to EqualLogic with Starwind Starport Initiator
Postby anton (staff) » Thu Jun 14, 2012 6:26 pm
1) There's no log attached :)
2) Why do you want to use StarPort instead of MS iSCSI initiator? Reason?
Postby wauters » Fri Jun 15, 2012 8:16 am
Right, let's try that log again... I noticed the error messages this time: erm... which extensions *are* allowed?
So let's try this <Code> button:
6/13 17:51:24.457 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:24.863 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:25.268 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:25.674 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:26.079 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:26.485 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:26.891 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:27.296 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:27.702 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:28.107 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:28.513 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:28.919 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:29.324 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:29.699 CWPPiSCSITargetSelection::CreateDevice: Trying to add an iSCSI device using TargetName=iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1, IP:0xA060101, Port:3260
6/13 17:51:29.699 >> CStarPortAPI::CStarPortAPI()
6/13 17:51:29.699 >> CStarPortAPI::DriverOpen()
6/13 17:51:29.699 >> CStarPortAPI::DriverVersion(...)
6/13 17:51:29.699 CStarPortAPI::DriverVersion: Calling STARPORT_IOCTL_GET_VERSION
6/13 17:51:29.699 CStarPortAPI::DriverVersion: Calling DeviceIoControl(...)
6/13 17:51:29.699 CStarPortAPI::DriverVersion: Input: ApiVersion = 30001
6/13 17:51:29.699 CStarPortAPI::DriverVersion: Output: Version = 20110316, API = 30001, DriverOpenContext = 0, DriverInstance = FFFFFA8005844B90
6/13 17:51:29.699 CStarPortAPI::CStarPortAPI: StarWind iSCSI Initiator version: 20091223; StariSCSI driver: API v30001, Build 0x20110316
6/13 17:51:29.699 >> CStarPortDoc::CreateiSCSIDevice(IP=0x26E6CE0, Port=3260, TargetName=iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1, Flags=0)
6/13 17:51:29.699 >> CStarPortAPI::InsertiSCSIDevice(dwIPAddress=0xA060101, dwPort=3260, szInitiaotrName=iqn.2003-06.com.starwindsoftware.starport:optiplex960, szTargetName=iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1, szAdditionalParameter=, nTargetID=...)
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: Calling STARPORT_IOCTL_TARGET_MOUNT
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: Input buffer:
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: Flags = 0
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: ServerAddress = #iscsi:10.6.1.1:3260
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: Parameter[0] = InitiatorName=iqn.2003-06.com.starwindsoftware.starport:optiplex960
6/13 17:51:29.699 CStarPortAPI::InsertiSCSIDevice: Parameter[1] = TargetName=iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1
6/13 17:51:29.730 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:30.135 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:30.541 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:30.947 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:31.352 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:31.758 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:32.163 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:32.569 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:32.975 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:33.380 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:33.786 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:34.191 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:34.597 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:35.003 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:35.408 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:35.814 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:36.219 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:36.625 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:37.031 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:37.436 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:37.842 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:38.247 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:38.653 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:38.731 CStarPortAPI::InsertiSCSIDevice: Session failed, status == 1326 !
6/13 17:51:38.731 >> CStarPortAPI::~CStarPortAPI()
6/13 17:51:38.731 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Logon to the server failed.
6/13 17:51:38.731 CWPPiSCSITargetSelection::CreateDevice: Failed to connect to create iSCSI device using TargetName=iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1, IP:0xA060101, Port:3260
6/13 17:51:38.731 CWPPiSCSITargetSelection::CreateDevice: Creation of the iSCSI device failed with all the addresses supplied by the server.
6/13 17:51:38.731 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Creation of the iSCSI device failed with all the addresses
6/13 17:51:39.059 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:39.464 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:39.870 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:40.275 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:40.681 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:41.087 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:41.492 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:41.898 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:42.303 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:42.709 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:43.115 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:43.520 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:43.926 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:44.331 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:44.737 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:45.143 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:45.548 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:45.954 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:46.359 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:46.765 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:47.171 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:47.576 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:47.982 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:48.387 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:48.793 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:49.199 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:49.604 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:50.010 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:50.415 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:50.821 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:51.227 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:51.632 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:52.038 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:52.443 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:52.849 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:53.255 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:53.660 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:54.066 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:54.471 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:54.877 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:55.283 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:55.688 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:56.094 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:56.499 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:56.905 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:57.311 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:57.716 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:58.122 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:58.527 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:58.933 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:59.339 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:51:59.744 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:00.150 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:00.555 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:00.961 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:01.367 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:01.772 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:02.178 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:02.583 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:02.989 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:03.395 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:03.800 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:04.206 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:04.611 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:05.017 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:05.423 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:05.828 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:06.234 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:06.639 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:07.045 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:07.451 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:07.856 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:08.262 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:08.667 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:09.073 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:09.479 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:09.884 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:10.290 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:10.695 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:11.101 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:11.507 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:11.912 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:12.318 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:12.723 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:13.129 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:13.535 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:13.940 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:14.346 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:14.751 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:15.157 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:15.563 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:15.968 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:16.374 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:16.779 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:17.185 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:17.591 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:17.996 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:18.402 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:18.807 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:19.213 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:19.619 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:20.024 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:20.430 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:20.835 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:21.241 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:21.647 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:22.052 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:22.458 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:22.863 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:23.269 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:23.675 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:24.080 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:24.486 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:24.891 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:25.297 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:25.703 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:26.108 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:26.514 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:26.919 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:27.325 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:27.731 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:28.136 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:28.542 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:28.947 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:29.353 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:29.759 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:30.164 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:30.570 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:30.975 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:31.381 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:31.787 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:32.192 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:32.598 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:33.003 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:33.409 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:33.815 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:34.220 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:34.626 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:35.031 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:35.437 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:35.843 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:36.248 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:36.654 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:37.059 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:37.465 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:37.871 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:38.276 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:38.682 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:39.087 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:39.493 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:39.899 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:40.304 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:40.710 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:41.115 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:41.521 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:41.927 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:42.332 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:42.738 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:43.143 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:43.549 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:43.955 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:44.360 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:44.766 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:45.171 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:45.577 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:45.983 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:46.388 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:46.794 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:47.199 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:47.605 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:48.011 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:48.416 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:48.822 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:49.228 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:49.633 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:50.039 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:50.444 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:50.850 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:51.256 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:51.661 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:52.067 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:52.472 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:52.878 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:53.284 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:53.689 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:54.095 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:54.500 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:54.906 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:55.312 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:55.717 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:56.123 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:56.528 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:56.934 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:57.340 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:57.745 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:58.151 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:58.556 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:58.962 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:59.368 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:52:59.773 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:53:00.179 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:53:00.584 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 17:53:00.584 >> CDriveLetterMap::~CDriveLetterMap()
6/13 17:53:00.584 >> CStarPortAPI::~CStarPortAPI()
wauters
Postby wauters » Fri Jun 15, 2012 8:21 am
So now one of my post disappeared?
Let's type it out again:
The reason we are trying Starport is that we are troubleshooting bandwidth/IO issues.
But the reason for this thread is that we are foxed that we can't figure out how to connect with Starport?
wauters
Postby anton (staff) » Fri Jun 15, 2012 9:55 am
1) It's more convenient to send logs zipped to [email protected] e-mail alias.
2) EQL rejects logon parameters for a reason. Do you have any way to get it from EQL? Logs or whatever? I really don't want to put engineer on a remote session in this case...
wauters wrote:Right, let's try that log again... I noticed the error messages this time: erm... which extensions *are* allowed?
Postby anton (staff) » Fri Jun 15, 2012 9:57 am
What do you mean? All of your posts are present and nothing was deleted.
I suspect the problem is on EQL side. Kick EQL support to get what's disliked in StarPort logon block and we'll be done.
wauters wrote:So now one of my post disappeared?
Postby wauters » Fri Jun 22, 2012 9:19 am
#1
I pressed the 'save' as draft button by mistake, then changed my mind, and then clicked 'submit'. Which resulted in no post at all.
#2
OK, I'm looking at the log on the eQuallLogic and the plot thickens: it shows a successful login from Startport,
and then a logout...
Maybe this is because Starport has trouble creating a drive entry on the windows machine?
INFO     6/22/12 10:20:17 AM  spim1   iSCSI session to target '10.6.1.2:3260, iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1' from initiator '10.6.1.110:49169, iqn.1991-05.com.microsoft:optiplex960' was closed.   Logout request was received from the initiator.
INFO     6/22/12 10:20:17 AM  spim1   iSCSI session to target '10.6.1.2:3260, iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1' from initiator '10.6.1.110:49175, iqn.1991-05.com.microsoft:optiplex960' was closed.   Logout request was received from the initiator.
INFO     6/22/12 10:19:59 AM  spim1   iSCSI login to target '10.6.1.2:3260, iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1' from initiator '10.6.1.110:49175, iqn.1991-05.com.microsoft:optiplex960' successful, using standard frame length.
INFO     6/22/12 10:19:56 AM  spim1   iSCSI login to target '10.6.1.2:3260, iqn.2001-05.com.equallogic:8-cb2b76-315e1f15a-6d0002638444fd5f-spim1-1' from initiator '10.6.1.110:49169, iqn.1991-05.com.microsoft:optiplex960' successful, using standard frame length.
wauters
Postby anton (staff) » Fri Jun 22, 2012 11:12 am
Not really, it looks like StarPort disconnects because EQL had rejected handshake parameters. Can you supply FULL log from EQL to us?
wauters wrote:#1
#2
Postby wauters » Tue Sep 11, 2012 12:39 pm
Apparently, the Equallogic group manager doesn't even log the Starwind Initiator's attempt.
All we have to go on is the Initiators error message on the Windows client side:
"Creation of iSCSI device failed with all the addresses supplied by the server."
Are our iSCSI target names too long?
For example:
iqn.2001-05.com.equallogic:8-cb2b76-883e1f15a-9ba002638244f461-spim1-0
The following is an entry we get with Window's built-in iSCSI connector:
Level Received Member Account Message
Info 09/11/2012 14:07 spim1 iSCSI login to target '10.6.1.2:3260, iqn.2001-05.com.equallogic:8-cb2b76-883e1f15a-9ba002638244f461-spim1-0' from initiator '10.6.1.110:49987, iqn.1991-05.com.microsoft:optiplex960' successful, using Jumbo Frame length.
wauters
Postby Anatoly (staff) » Thu Sep 13, 2012 1:32 pm
So, you can confirm that you can successfully connect to EL using MS initiator, correct?
Well, lets try to change the target name to something shorter. will it be possible for you?
[email protected]
Return to StarPort
Who is online
