Automount this device (Greyed out)
Phan7
Sat Apr 28, 2012 4:35 pm
Guys, I have tried and tried different things to get this working.
This check box is currently greyed out on W2K8, W2K3 and Win7 for an iSCSI mirror device (both devices remote)
There seems to be no workaround to get the devices, whether simple/dynamic, to auto-mount on system startup or even get that check box working.
Is anyone experiencing the same? I have seen people state in other threads that this checkbox is functional and working, please help!
Tue May 01, 2012 8:22 pm
Hello Phan7,
do you mean that you see automaunt checkbox greyed out when you are already connected to the target and you viewing Preferences window or do you see it in the wizard?
Phan7
Wed May 02, 2012 4:01 pm
Hi Anatoly, yes it's after I have added the mirror using your iSCSI initiator, when viewing preferences for the item it's greyed out.
Also, I have checked application prefs, on the mirror tab, automount is checked and the control is enabled. But it does not automount.
Cheers
Fri May 04, 2012 1:26 pm
OK, we are trying to reproduce the issue in our test lab.
We`ll keep you updated.
Phan7
Fri May 04, 2012 2:31 pm
Sun May 06, 2012 10:18 pm
Yes, the issue is reproduced and our R&D assured that we will put this improve in our To-Do list.
Thank you for your cooperation :)
Phan7
Mon May 07, 2012 9:59 am
Hey nice one for that, nobody else has been whinging about it and I thought it was likely just me! :roll:
Tue May 08, 2012 10:43 pm
Funny but we don't even remember why we've disabled it...
Phan7
Mon May 14, 2012 12:26 am
You need change management :lol:
Saying that, I don't even like change management :P
Mon May 14, 2012 3:38 pm
Well, I don`t think its the best idea ever :)
OK, We`ll keep you updated and will let you know when we`ll fix it.
Thank you for cooperation 8)
Mon May 28, 2012 9:16 am
Please grab an updated version. Automount for RAID/JBOD devices has been added.
Phan7
Sun Jun 10, 2012 1:53 pm
OK thanks, shall do :)
Sun Jun 10, 2012 2:25 pm
Please let us know how it worked. Thanks!
Phan7 wrote:OK thanks, shall do :)
Phan7
Sun Jun 10, 2012 3:01 pm
Anton, this has worked wonders thankyou for taking this on board.
I created 2 x 10GB on my test box and wiped, added some data, rebooted... Mirrors reconnected.
Gave it a good thrashing afterwards and alls well :)
Sun Jun 10, 2012 9:53 pm
Fine. Thank you very much for keeping us updated. Much appreciated.
Locked
