Problems with NTBACKUP
Hobe
Wed Jun 30, 2004 8:33 pm
The problem:
1. Machine: W2K SP4 Server (German) with StarWind and "add \\.\Tape0" in the config file.
2. Machine: WXP SP1 Prof. Workstation (German) with StarPort. The remote tape drive was successfully created. Now I ┤d like to backup drive c with NTBACKUP. After a few seconds I get the error message (translated): The device reports an error during processing following comands: Error writing data onto medium... Errormessage: Illegal command.
3. Machine W2K SP4 Prof. Workstation (German) with StarPort. The remote tape drive was successfully created. The backup works fine...
Now then question: What┤s wrong with the combination W2K Server and WXP Prof.?
Any ideas?
Hobe
Alex (staff)
Thu Jul 01, 2004 10:10 am
Can you show StarWind's log file that shows the moment when NTBACKUP fails? (2)
Alexey.
Guest
Thu Jul 01, 2004 10:53 pm
Alex (staff) wrote:Can you show StarWind's log file that shows the moment when NTBACKUP fails? (2)
Sorry, the error log is empty!
Hobe
Thu Jul 01, 2004 11:43 pm
Hobe,
I would kindly ask you
1)
run regedit.exe, go to
HKLM\System\CurrentControlSet\Services\StarWindService\Parameters
key and edit string named
"CommandLine". You should see something like this:
"C:\Program Files\Rocket Division Software\StarWind\StarWindService.exe
-l0
-cC:\Program Files\Rocket Division Software\StarWind\starwind.conf
-o"
please change "-l0" parameter to "-l1". This would raise log level from default 0 (only critical errors) to 1 (some extended debug information).
2) Restart StarWind Service typing
"net stop StarWindService" and "net start StarWindService" in the command console.
3) Rerun your actions resulting problems.
4) Send us log.
Thank you very much for cooperation! We appreciate you help in making our software better!
Hobe
Alex (staff)
Fri Jul 02, 2004 10:19 am
Hobe,
Actually it would be much better if you set the logging level to 3 - all messages (i.e. -l3) and repeat the problem. Then I will have much more detalied information. Thank you.
Alexey.
