Greetings. Currently doing some small scale testing of the Windows-based AoE initiator. I've compiled the latest Linux kernel driver from http://support.coraid.com/support/linux/aoe6-77.tar.gz on my Arch Linux machine.
Was able to add the following to /etc/rc.local:
/sbin/modprobe aoe
/usr/sbin/vbladed 0 1 eth0 /dev/sdb1
/dev/sdb1 was a ext4 formatted partition but under Windows I formatted as a NTFS drive. Any reason I can't mount it under linux? I used:
mount -r -t ntfs /dev/sdb1 /aoe but it came back with the error message of wrong fs type, bad superblock, bad option on /dev/sdb1.
Thanks for the help!
