StarPort crashes on Windows Server 2003
birtha
Mon Feb 23, 2009 5:15 pm
StarPort keeps crashing on our IBM xseries_346 with MS Windows Server 2003 R2 Standard Edition SP2. We are using the iSCSI StarPort linking to a Thecus N5200PRO (firmware 2.00.14).
With out iSCSI working we have no way of getting to our data. We are copying files to the Thecus using Backup Exec 12.5.
Been working w/Filimonov with no resolution as of yet. Just wondering if anyone else is having similar problems.
Below are 2 error logs from produced crashes. Since this has happened we updated StarPort to version 4.0 Build 0x20090220.
All of this seemed to happen after MS updates were installed. We don't have automatic updates turned on, so unsure how this even happened. Updates are listed after error logs.
Starport 3.6.3 Build 0x20081210 seems to be crashing unexpectedly.
When trying to launch I get this error: StarPort Storage Controller has encountered a problem and needs to close.
Here are the 2 Error logs from the Event Viewer:
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 2/18/2009
Time: 7:57:58 AM
User: N/A
Computer: MADSRVR02
Description:
Faulting application starport.exe, version 3.6.3.1210, faulting module starport.exe, version 3.6.3.1210, fault address 0x000461f3.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 73 74 61 ure sta
0018: 72 70 6f 72 74 2e 65 78 rport.ex
0020: 65 20 33 2e 36 2e 33 2e e 3.6.3.
0028: 31 32 31 30 20 69 6e 20 1210 in
0030: 73 74 61 72 70 6f 72 74 starport
0038: 2e 65 78 65 20 33 2e 36 .exe 3.6
0040: 2e 33 2e 31 32 31 30 20 .3.1210
0048: 61 74 20 6f 66 66 73 65 at offse
0050: 74 20 30 30 30 34 36 31 t 000461
0058: 66 33 0d 0a f3..
Event Type: Error
Event ID: 1000
Date: 2/18/2009
Time: 8:00:04 AM
User: N/A
Computer: MADSRVR02
Description:
Faulting application starport.exe, version 3.6.3.1210, faulting module starport.exe, version 3.6.3.1210, fault address 0x0003d660.
Data:
0050: 74 20 30 30 30 33 64 36 t 0003d6
0058: 36 30 0d 0a 60..
Event Type: Information
Event Source: Windows Update Agent
Event Category: Installation
Event ID: 18
Date: 2/17/2009
Time: 2:31:37 PM
User: N/A
Computer: MADSRVR02
Description:
Installation Ready: The following updates are downloaded and ready for installation. This computer is currently scheduled to install these updates on Wednesday, February 18, 2009 at 3:00 AM:
- Security Update for Windows Server 2003 (KB958687)
- Security Update for Windows Server 2003 (KB952954)
- Security Update for Windows Server 2003 (KB954600)
- Security Update for Windows Server 2003 (KB955069)
- Security Update for Windows Server 2003 (KB956802)
- Cumulative Security Update for Internet Explorer 7 for Windows Server 2003 (KB961260)
- Security Update for Windows Server 2003 (KB956841)
- Security Update for Windows Server 2003 (KB954211)
- Update for Windows Server 2003 (KB955839)
- Update Rollup for ActiveX Killbits for Windows Server 2003 (KB960715)
- Security Update for Microsoft XML Core Services 6.0 Service Pack 2 (KB954459)
- Security Update for Windows Server 2003 (KB958644)
- Security Update for Windows Server 2003 (KB938464)
- Security Update for Windows Server 2003 (KB952069)
- Security Update for Windows Server 2003 (KB957097)
- Security Update for Windows Server 2003 (KB956803)
- Security Update for Internet Explorer 7 for Windows Server 2003 (KB938127)
Robert (staff)
Tue Feb 24, 2009 2:46 pm
Dear birtha,
It appears that Starport's GUI is crashing for some reason.
Please send us the log files that Dmitry had requested from C:\Documents and Settings\%UserProfile%\Local Settings\Application Data\
Looking forward to hearing back and thank you very much for your cooperation! We appreciate it!
Rob
Robert
StarWind Software Inc.
