Installed StarPort with Coraid Etherdrive no Disks???
jsinclair
Wed May 07, 2008 1:57 pm
I recently installed the trial version of StarPort to test out our new AoE Coraid EtherDrive. I am testing it on a Windows XP sp2 workstation before I try production. I have been able to add the AoE device, but nothing appears in Windows "Disk Management". I have rebooted, tried several times, it shows up in Device Manager under disks, but nowhere can I see it. It is a RAID10 setup with 6 1TB drives (3TB) on the EtherDrive.
Please, anyone have any suggestions/help??
Jason
Wed May 07, 2008 4:59 pm
Your OS does not support 2TB+ volumes. Either upgrade it or split CoRAID storage into smaller chunks (say 1.5TB each). You have ZERO chances for success in your current configuration.
jsinclair
Wed May 07, 2008 5:02 pm
I will give that a shot.
Does Windows 2003 Server x64 R2 SP2 support 3TB ?
Wed May 07, 2008 5:14 pm
YES
jsinclair wrote:I will give that a shot.
