22 February, 12:45-1:10 pm ET
Speakers: Max Kolomyeytsev, Director of Product Management
Universally accepted redundancy levels are clearly insufficient for environments running multiple independent workloads. Applications crucial for your business like Databases or ERP systems demand the highest possible uptime and resiliency which goes beyond standard protection against 1 node or 1 disk failure. StarWind HyperConverged Appliance combines Local Reconstruction Codes, Replication and Grid Architecture to give you an immense extent of fault tolerance while delivering sustained high performance. It easily withstands multiple disk or even node failures without disrupting the work of the whole infrastructure. In the event of a failure applications are automatically recovered to working disks or nodes of the cluster. With StarWind HCA your applications remain resilient and operational even if more than 50% of the cluster nodes go down.
