Accelerate your performance by deploying iSER to your StarWind infrastructure
15 September, 11 am PT / 2 pm ET
Host: Oles Borys, Director of Support Department, StarWind
StarWind Virtual SAN supports majority of industry-standard uplink protocols, which enables it to work with almost all virtual environments and technologies. Now StarWind VSAN works also with iSER, which is a topnotch extension of data transfer model of iSCSI with RDMA.
iSER is by times faster than iSCSI and easy to manage. With RDMA protocol suite, it supplies higher bandwidth for block storage transfers. It has the lowest latency and lowest CPU utilization. Besides, it is stable and saves advantages of the iSCSI protocol like security and high availability.
Join our tap room and learn how to configure iSER, which enforces StarWind by unloading CPU and speeding up the performance. StarWind engineer will provide you with the instructions on that and will also demonstrate the resulting system performance.
