StarWind iSCSI SAN
Problem with RDX-Drive
Tape drive and auto-loader redirector (iSCSI)
Postby FrankB » Thu Feb 28, 2019 7:35 am
Hello, I'm using Tape Redirector to make use of an Tandberg USB-RDX-drive, that is attached to an HyperV Win2016-Server, inside a HyperV-Guest with SBS2011. The drive is shared in drivebridge-mode in starwind.
My problem is, that the Guest-OS does'nt recognize, if the RDX-cartridge was changed. I have to stop and restart the starwind-service on the host, only then the new cartridge is visible to the guest. Is there any trick or did I miss a setup step to avoid this service-restart?
Best regards, Frank
Frank Briesemeister
Berlin/Germany
FrankB
Re: Problem with RDX-Drive
Postby Oleg(staff) » Fri Mar 01, 2019 1:31 pm
Hello Frank,
Could you please collect the logs and share with us?
Please use this tool for log collection.
Oleg(staff)
Postby jenniferfonseca » Sun Mar 10, 2019 5:28 pm
Have you got the chance to solve the problem? If so, let me know how did you guys fix the issue?
jenniferfonseca
Postby Boris (staff) » Tue Mar 12, 2019 3:05 pm
The case is being investigated. Community will be updated once any result is available.
Postby FrankB » Thu Mar 14, 2019 8:22 am
Hello Oleg,
sorry for the delay, I had no information about your answer and only today I was actively logging into the forum and found your message. I collected the logs as adviced and tried to attache it here, but got an error "The file is too big, maximum allowed size is 256 KiB.". The zipped file generated by your tool has 1,4MB. Do you have another upload or can I send you an Email?
Best regards, Frank
Frank Briesemeister
Berlin/Germany
FrankB
Postby Oleg(staff) » Thu Mar 14, 2019 8:33 am
Hello Frank,
You can upload the logs to some fileshare resouse and send the link for download.
Oleg(staff)
Postby FrankB » Fri Mar 15, 2019 1:38 pm
you may download the file from https://drive.google.com/file/d/1CGVEEwmDPVgglOAcBJPX6IaaZCqiEr-R/view?usp=sharing
Thanks in advance.
Best regards
Frank
Frank Briesemeister
Berlin/Germany
FrankB
Postby Oleg(staff) » Mon Mar 18, 2019 9:01 am
Hello Frank,
Thank you for the logs.
I will check and give you an update.
Oleg(staff)
Postby Oleg(staff) » Mon Mar 18, 2019 2:23 pm
Hello Frank,
I have checked the logs.
Yes, that is expected behaviour. StarWind opens drive to make it accessible over ISCSI. When the disk is being changed, the client still has "old" disk open until the service is restarted.
This can be solved also by reconnecting ISCSI sessions to the target. It will close the disk with last sessions disconnected and re-open it when the first new session arrives.
Oleg(staff)
Postby FrankB » Mon Mar 18, 2019 2:33 pm
Hello Oleg,
thank you for the information. I expected it a little more "automatic", because classic tape drives also contain changeable cartridges. So in my opinion a "tape redirector" has to deal with cartridge changes all the time. Anyhow, if I restart the starwind service it will actualize the cartridge, right? Or do I have to restart the initiator-service on the client-side, too?
Best regards
Frank
Frank Briesemeister
Berlin/Germany
FrankB
Postby Oleg(staff) » Mon Mar 18, 2019 3:56 pm
Frank,
For tapes, we have a little bit different mechanism than for drivebridge.
Correct, that should work.
Oleg(staff)
Return to StarWind Tape Redirector
Who is online
