StarWind iSCSI SAN
Free version of "StarWind Tape Redirector" and "Device Type is not licensed"
Tape drive and auto-loader redirector (iSCSI)
Postby massoo » Tue Jan 23, 2018 11:50 am
I am on the path of evaluating the "StarWind Tape Redirector" and registered for the download. In the subsequent email, I got the license file as "StarWind_Tape_Redirector_Free_License_Key.swk" file through registered email.
I downloaded the StarWind Tape Redirector (which is now part of a free version of StarWind Virtual SAN) from the link http://starwindsoftware.com/tmplink/starwind-v8.exe and installed both FULL version and "VTL & Cloud redirector". I applied the provided license.
When I try to a VTL as:
StarWind MMC >> Add Device (advanced) >> Select Tape Device >> Select the Virtual Tape item >> Next >> Error >> "Device Type is not licensed, you are using free License. Contact Support"
I am wondering if "StarWind Tape Redirector" is free to use or not?
Prashant
massoo
Re: Free version of "StarWind Tape Redirector" and "Device Type is not licensed"
Postby Boris (staff) » Tue Jan 23, 2018 12:30 pm
Prashant,
You are trying to use Virtual Tape Library (VTL), which is not Tape Redirector. Please contact Sales for the key with VTL enabled.
Postby massoo » Tue Jan 23, 2018 12:53 pm
How do I install the "StarWind Tape Redirector" and use it?
massoo
Postby Boris (staff) » Tue Jan 23, 2018 4:02 pm
Check this link on how to use Tape Redirector hhttps://www.starwindsoftware.com/techn ... rector.pdf
Postby massoo » Wed Jan 24, 2018 10:45 am
Thanks. I am able to configure the TL, Server and present to remote VEEAM B & R Suite, write into tape backup sets from VEEAM B & R suite.
massoo
Postby Boris (staff) » Wed Jan 24, 2018 11:23 am
massoo,
Is your issue with licensing resolved now?
Return to StarWind Tape Redirector
Who is online
