StarWind iSCSI SAN
Issues connecting to iSCSI target
Tape drive and auto-loader redirector (iSCSI)
Postby TTwa » Wed Nov 16, 2016 6:15 pm
I have installed/configured the Starwind Tape Redirector and, while I can added to iSCSI initiator locally, I can't connect to the iscsi target from a VM on the same lan. Firewalls are off.
I followed these instructions:
https://www.starwindsoftware.com/tape-drives-using-starwind-and-veritas-backup-exec
The default port was changed to 3260.
On the VM in question I get this warning:
iSCSI discovery via SendTargets failed with error code 0x00002af9 to target portal *iqn.2008-08.com.starwindsoftware:server.domain.com-tapelib 0003260 ROOT\ISCSIPRT\0000_0 .
What could be the issue?
Thanks for your time!
TTwa
TTwa
Re: Issues connecting to iSCSI target
Postby TTwa » Mon Nov 21, 2016 4:45 pm
Does anyone have any ideas on what I could try?
TTwa
Postby TTwa » Mon Nov 21, 2016 9:30 pm
I figured it out. Since I alredy had SAN connections on 3260, I changed to starwind port to a free port and I was able to connect the iscsi.
Instructions here:
https://knowledgebase.starwindsoftware. ... ort-value/
Even though iSCSI is connected I still can't see the tape library on my test VM..
TTwa
Postby Oles (staff) » Thu Nov 24, 2016 5:03 pm
Hello, could you please submit a support ticket via support form and you will be contacted by an engineer.
Thank you for your patience.
Oles (staff)
Return to StarWind Tape Redirector
Who is online
