StarWind iSCSI SAN
Tape Redirector with HP MSL2024 Multiple Drives.
Postby david.buchanan » Thu Dec 24, 2015 6:28 am
I'm testing the Starwinds tape redirector software with our HP MSL2024 tape library which has two LTO 5 drives.
When I configure the Starwinds software I can only get the library and one drive to work. How do I configure it so that both tape drives appear?
David
david.buchanan
Re: Tape Redirector with HP MSL2024 Multiple Drives.
Postby Vladislav (Staff) » Mon Dec 28, 2015 7:45 pm
Hello David,
Did you install HP drivers?
Download link: http://goo.gl/5V5sNp
Vladislav (Staff)
Postby david.buchanan » Tue Jan 05, 2016 5:12 am
Hi Vladislav,
Sorry for the slow reply, New Years and all :)
Yes, I have installed the HP drivers. Perhaps I'm configuring it wrong. If there a specific guide for configuring a Tape Library with multiple drives with the redirector?
David
david.buchanan
Postby david.buchanan » Fri Jan 08, 2016 2:07 am
Any update on this?
David
david.buchanan
Postby Vladislav (Staff) » Mon Jan 11, 2016 12:14 pm
Hello David,
Please note that according to HP instruction each of the tape drives uses one channel and the cable recommended for use with the Library maps each of the four channels from the HBA to one channel on the drive end.
Could you please make sure that your SAS cables are connected properly?
Here is the guidance on how to install and configure StarWind Tape Redirector for ARCserve backup: https://www.starwindsoftware.com/technical_papers/StarWind_Tape_auto-loader_changer_Device_2011.pdf
Vladislav (Staff)
Return to StarWind Tape Redirector
Who is online
