Starwind Beta8 under W2k12R2 and Library DELL PV-122T
kamo_1969
Thu Mar 06, 2014 5:08 pm
OK downloaded and installed starwind 8 beta.
Loader (Dell PV-122T) under host environment (device manager) recognized, in 'media changer devices' and 'tape libraries'. Attached to host computer (x3650) by adaptec 29230 card, os is w2k12r2.
Successfully Imported tape loader in starwind management console. Made target ok.
Target successfully attached to host. In management console (Starwind) there is indicated connection.
DPM in host server show up library and 8 slots.
But no command is working. Scan, Inventory etc product no viewable results. DPM is producing alerts like
Before this library were full working in old w2k3 server.
What can I do next? Is it any way to check if library is accepting commands in management window?
Thu Mar 06, 2014 5:28 pm
Start with replacing Beta with Release Candidate. Then make sure you've adjusted request buffer size on initiators as it's not what we can do automatically w/o operator intervention. See:
http://www.starwindsoftware.com/forums/ ... t1089.html
If it would not work please make sure ypu provide us with StarWind logs as it's very difficult to deal on your issue description only. Then we'll be happy to proceed with troubleshooting. Thank you!
kamo_1969
Thu Mar 06, 2014 5:39 pm
Ok your colleague Anatolyi pointed me to Beta download link.
Where I can get Release Candidate Starwind 8 ?
Thu Mar 06, 2014 5:47 pm
You are welcomed to sign up to our Beta Testing program by using the link below and filling the forms:
www.starwindsoftware.com/starwind-v8-beta
After we receive your contact information you`ll get the v8 RC and the trial license key.
I hope that helped.
kamo_1969
Fri Mar 07, 2014 8:54 am
i was confused today. I used link you wrote and probably have RC version installed.
In 'about' section of management console I have:
Management Console: 8.0.6441, SPTI, tape, tapeLSFS etc - all is in version 8.0
So I think I have latest version. But guest via iscsi doing nothing with library. I will check http://www.starwindsoftware.com/forums/ ... t1089.html today, but have another question.
Could you help me where to get SCSI Persistent Reservation Test tool, like PResTest v 1.0?
Bohdan (staff)
Fri Mar 14, 2014 12:13 pm
The tool was sent. Please check your e-mail.
adson3492
Fri Nov 14, 2014 6:17 am
Thanks.
Can I split the drives - one drive for acronis, and one for DPM.
If not, can I create one iSCSI target that is used by both - presumably there I will be able to instruct the software as to which partition to use?
Fri Nov 14, 2014 10:03 am
You can connect two drives to different apps as long as they do have different SCSI addresses.
No you cannot share the same tape device between multiple app @ the same way. These types of accesses are exclusive.
adson3492 wrote:Thanks.
