allan.mc.nz
Thu Apr 11, 2013 9:19 am
Ive installed the free tape redirector but when I connect I can see the device but in device manager its shown as a unknown device and then wont be shown in DPM 2012.
Both servers are runnings Windows Server 2012, can anyone help me find a driver that will work on the client machine to allow DPM to see and work with the drive?
Max (staff)
Mon Apr 15, 2013 9:02 am
You need to install your Dell tape device driver on the client machine, since you're passing through the whole device - client machine controls it the same way as original owner.
Max Kolomyeytsev
wicky
Mon Nov 10, 2014 6:19 am
wicky on Wed Nov 26, 2014 10:13 am, edited 1 time in total.
Mon Nov 10, 2014 2:51 pm
Well, that should be the same driver that you`d use without the Tape Redirector software. Can you share the tape model with us?
