Tape Redirector adding Targets to iSCSI
vsolution
Tue Apr 02, 2013 4:29 pm
We have a server 2012 hyper-v host that has the starwind tape redirector software installed successfully, and a server 2012 guest server where where we are trying to view a tape drive that is directly connected to host server. Following install isntructions for tape redirector software, we get to the point where we do the discovery and it finds the host, but no targets appear in the iSCSI initiator. Everything looks good from the starwind software side, just confused why no targets appear for us. Anybody else have this issue with adding the target to iSCI ?
Tue Apr 02, 2013 7:25 pm
Do you have tape drive actually installed? Is there any chance you'd supply us with a StarWind log on attempt to connect to it and see what's exported.
Also make sure you run the most recent version of StarWind Tape (ask support@starwindsoftware.com for download URL, key file you have should work).
