make tape drive on hyper-v host available within vm guest
tmichiels
Thu Oct 18, 2012 10:36 pm
Just to be sure, is the following possible: we have a server (hp proliant ml 350 g8) with an hp ultrium 3000 LTO-5 tape drive in it. We would very much like to use virtualization on it but need to access the tape drive from a guest (running Windows server 2008 with backup exec 2012).
We are considering to use Hyper-v server 2012 as hypervisor.
Would this be possible with the tape redirector software?
thanks
Tom
Fri Oct 19, 2012 6:36 am
Yes, that's exactly the case for that product. Just make sure you've limited I/O transfer size on your initiator as it's discussed on forums.
tmichiels
Fri Oct 19, 2012 7:05 am
thus you can install the tape redirector software on the host running windows 2012 core (hyper-v) ? Is there some sort of procedure for, since you don't gave a GUI?
thanks
Tom
Fri Oct 19, 2012 8:51 am
You install a service app where tape drive resides. And run a GUI from where you want. Just install TR and select what do you want to install - service, management console (GUI) or both.
tmichiels wrote:thus you can install the tape redirector software on the host running windows 2012 core (hyper-v) ? Is there some sort of procedure for, since you don't gave a GUI?
thanks
Tom
tmichiels
Tue Oct 23, 2012 1:15 pm
I've installed the service app on the hyper-v core server. I'm using the Microsoft iSCSI initiator to connect to the tape drive which succeeded without any serious problems.
Anyway, question: the backup is very very slow... I only get a throughput of 8 MB/sec while this tape drive can do a few 100 MB/sec - any idea?
rgds
Tom
Tue Oct 23, 2012 4:58 pm
Are you running everything in a loopback? Or using physical network? Get nttcp and iperf and check how fast can TCP do between target and initiator.
Let us know the numbers and we'll proceed. Thanks!
tmichiels wrote:Hi,
rgds
Tom
tmichiels
Tue Oct 23, 2012 5:38 pm
From target (core server with tape) -> initiator (guest os with backup software):
C:\>iperf -c x.x.x.8
Client connecting to x.x.x.8, TCP port 5001
TCP window size: 64.0 KByte (default)
[192] local x.x.x.12 port 49163 connected with x.x.x.8 port 5001
[ ID] Interval Transfer Bandwidth
[192] 0.0-10.0 sec 2.94 GBytes 2.52 Gbits/sec
And vice versa:
C:\>iperf -c x.x.x.12
Client connecting to x.x.x.12, TCP port 5001
TCP window size: 8.00 KByte (default)
[196] local x.x.x.8 port 12912 connected with x.x.x.12 port 5001
[196] 0.0-10.0 sec 2.61 GBytes 2.24 Gbits/sec
I should expect more since the hyper-v guest is connected thru a 10 gbit virtual NIC with the host and this is a new gen 8 HP server...
But still, I don't understand why the backup throughput is only <100 mbit
thanks for your help!
tmichiels
Thu Oct 25, 2012 2:10 pm
I agree tape drives are not the fastest devices, but this one is an HP Ultrium LTO-5 3000 tape drive and when we do a backup directly on it, we get speeds up to 15 times what we achieve now using the tape redirector software?
Thus is there any fine tuning to do? Can we optimize things? Because you asked me to give iperf stats before looking further?
Thu Oct 25, 2012 2:50 pm
With 2.5Gbps you can get your physical bandwidth with your tape (ignore 10 Gbps virtual network settings as they mean nothing really).
Can you move VM to another physical host and check how well it will perform over network? There are loopback issues with MS network stack solved with Windows Server 2012.
tmichiels wrote:I agree tape drives are not the fastest devices, but this one is an HP Ultrium LTO-5 3000 tape drive and when we do a backup directly on it, we get speeds up to 15 times what we achieve now using the tape redirector software?
tmichiels
Thu Oct 25, 2012 2:58 pm
anton (staff) wrote:With 2.5Gbps you can get your physical bandwidth with your tape (ignore 10 Gbps virtual network settings as they mean nothing really).
No unfortunately I don't have any additional server with hyper-v.
About your remark about loopback issues : We are using Windows server 2012 as hyper-v server with windows 2011 abs (2008 R2) as guest...
Thu Oct 25, 2012 3:04 pm
It can be any Windows machine on network just fine. We're not talking about production, we're talking about experiment.
I know. We did a job @ our side so now waiting for MS to fix their initiator (or we'll end with a workaround solution) to speed up the things in 5x times at least. But it SHOULD NOT work THAT slow right now.
tmichiels
Sat Oct 27, 2012 2:00 am
Ok I did another test: I installed hyper-v server 2008 with the same tape and guest configuration. Now the backup is 5-10 x faster.
So could it be that the issues lies with Hyper-v server 2012?
Sat Oct 27, 2012 3:08 pm
Actually Windows 2012 was supposed to be better (some tricks applied to make loopback work faster). Could you please stick with a working config and we'll try Windows Server 2012 with a tape in a loopback?
tmichiels wrote:Ok I did another test: I installed hyper-v server 2008 with the same tape and guest configuration. Now the backup is 5-10 x faster.
tmichiels
Sun Oct 28, 2012 12:23 am
In the meanwhile, are these errors in the server log thing we have to worry about:
10/28 0:53:02.140 7b8 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_5-scsi#5&35356f5e&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
 0000  38 00 00 00 00 00 06 40 01 00 00 00 00 00 04 00 8......@........
 0010  e0 a5 01 00 00 00 00 00 90 49 4f 02 00 00 00 00 à¥......IO.....
 0020  38 00 00 00 08 00 04 00 00 00 00 00 00 00 00 00 8...............
 0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
 0070  00 00 00 00 00 00 00 00                         ........
10/28 1:21:57.298 7b8 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_5-scsi#5&35356f5e&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': scsiPassThrough failed: The parameter is incorrect. (code: 87).
10/28 1:21:57.298 7b8 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_5-scsi#5&35356f5e&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
10/28 1:21:57.298 7b8 SPTI: '\\?\scsi#sequential&ven_hp&prod_ultrium_5-scsi#5&35356f5e&0&000400#{53f5630b-b6bf-11d0-94f2-00a0c91efb8b}': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
Sun Oct 28, 2012 6:47 pm
I have an impression you did not patch the xfer size on your initiator box as you shoud be:
http://www.starwindsoftware.com/forums/ ... t1089.html
Could you please double-check this?
