Dear Beta-Team members,
Currently our Dev Team is working on the Tape Redirector product, which allows you to export tape drives and media changers as iSCSI targets over the network and connect them on remote machine.
The beta version is available for download from the following link:
http://www.starwindsoftware.com/beta/bu ... 302010.exe
and the license you can download from this link:
http://www.starwindsoftware.com/beta/bu ... a-Team.swk
Note: it uses tcp 33268 port for iSCSI communication, and tcp 33269 port for management console purpose. Therefore to start its management please specify 33269 port instead of 3261. To connect the exported targets with MS iSCSI initiator specify IP address of tape redirector machine and 33268 port instead of default 3260.
Known issues:
Management Console: Exporting "Add Export tape auto-loader/changer device" shows Tape drive symbolic name instead of auto-loader on the summary page.
Core: Tape drives are exported with clustering option enabled.
Management Console: contains StarWind iSCSI SAN Software Help
Installer: contains StarWind iSCSI SAN Software EULA
Please do not hesitate to contact us should you have any questions.
Let us remind you that StarWind started open beta testing program and the most active beta testers will win monthly prizes from StarWind: iPads and coupons for $100 from Amazon.com. The names of the first winners will be published on our beta forum page in the end of July.
