NTBACKUP - Restore
jejones
Mon Oct 04, 2004 7:19 pm
Given: StarWind on W2003 Server with StarWind 2.4.1, StarPort on WinXP SP2 mapping to tape drive on server.
A NTBackup full system backup works fine. When I attempt to restore a file from the backup, the tape rewinds, then I get the error "Error: an inconsistency was encountered on the requested media". The W2003 server is able to read this tape directly. I tried setting the log level for StarWind to 3 and the problem does not occur and the restore is successful. When I go down to log level 1 or 2, it fails again, but no obvious error is recorded in the log file.
There appears to be some sort of timing problem, but how to narrow down the problem?
Guest
Mon Oct 04, 2004 9:52 pm
jejones wrote:Given: StarWind on W2003 Server with StarWind 2.4.1, StarPort on WinXP SP2 mapping to tape drive on server.
Recent StarWind builds should work with tape drives good.
Which StarWind build do you use?
Also we fixed a tape related problem in StarPort about a month ago. But I suspect some other tape issue could still exist.
Not many people use tape devices shared with StarWind, so we have very limited feedback about this mode.
Could you please try the MS iSCSI initiator instead of our StarPort to access the shared tape drive?
If it works OK, this is definitely a StarPort's problem. So we'll be able to pin out the issue.
Thank you in advance.
jejones
Tue Oct 05, 2004 1:03 am
StarWind iSCSI Target Version 2.4.1 (Build 0x20040915, Win32)
With Microsoft ISCSI 1.05a, the restore fails "The device reported an error on a request to read data from media". This time there was an error in the StarWind log -
00:56:01:296 (0xcf0) SPTI: '\\.\Tape0': DeviceIoControl failed: The parameter is incorrect. (code: 87).
00:56:01:296 (0xcf0) SPTI: '\\.\Tape0': IOCTL_SCSI_PASS_THROUGH_DIRECT (before):
0000 2c 00 00 00 00 00 06 12 01 00 00 00 00 00 04 00 ,...............
0010 e0 a5 01 00 f0 d0 09 00 2c 00 00 00 08 01 00 01 ðå..¨╨..,.......
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00:56:01:296 (0xcf0) SPTI: '\\.\Tape0': IOCTL_SCSI_PASS_THROUGH_DIRECT (after):
Val (staff)
Tue Oct 05, 2004 9:08 am
Thank you for the info.
It seems to be a StarWind's problem...
We'll try to fix the issue.
Valeriy
