unfortunately, the problem with windows 2000 server (not virtualized) persist.anton (staff) wrote:SPTI problems inside the StarWind have very little to do with the MS initiator buffer size
Good. Please keep us updated about the progress.
log wrote: 9/27 12:03:29.824 aa8 Srv: Accepted iSCSI connection from 10.1.1.5:1484. (Id = 0xa)
9/27 12:03:29.824 aa8 C[a], FREE: Event - CONNECTED.
9/27 12:03:29.824 aa8 C[a], XPT_UP: T3.
9/27 12:03:29.839 fcc C[a], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
9/27 12:03:29.839 fcc C[a], XPT_UP: Event - LOGIN.
9/27 12:03:29.839 fcc C[a], IN_LOGIN: T4.
9/27 12:03:29.839 fcc Params: <<< String param 'InitiatorName': received 'pc0019', accepted 'pc0019'
9/27 12:03:29.839 fcc Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
9/27 12:03:29.839 fcc Params: <<< String param 'TargetName': received 'pc0063', accepted 'pc0063'
9/27 12:03:29.839 fcc Params: <<< Enum param 'AuthMethod': received 'CHAP', accepted 'CHAP'
9/27 12:03:29.839 fcc Tgt: : open 'pc0063': 1 session(s) opened, 0 more allowed.
9/27 12:03:29.839 fcc T[1]: CHAP authentication selected.
9/27 12:03:29.839 fcc Params: >>> AuthMethod=CHAP.
9/27 12:03:29.839 fcc Params: >>> TargetPortalGroupTag=1.
9/27 12:03:29.839 fcc Params: <<< Enum param 'CHAP_A': received '5', accepted '5'
9/27 12:03:29.839 fcc Params: >>> CHAP_A=5.
9/27 12:03:29.839 fcc Params: >>> CHAP_I=2.
9/27 12:03:29.839 fcc Params: >>> CHAP_C=0bWuvuAeHJgfhfIniO6fixutMAtDVAE8mWJT0GU5tZvhY=.
9/27 12:03:29.839 fcc Params: <<< String param 'CHAP_N': received 'uno', accepted 'uno'
9/27 12:03:29.839 fcc Params: <<< String param 'CHAP_R': received '0bNikeINGM9SYVB2KRhz1TBQ==', accepted '0bNikeINGM9SYVB2KRhz1TBQ=='
9/27 12:03:29.839 d30 T[1]: session 0xa, connection 0xa : end of stage 0, next stage 1.
9/27 12:03:29.839 fcc Params: <<< Enum param 'HeaderDigest': received 'None,CRC32C', accepted 'None'
9/27 12:03:29.839 fcc Params: <<< Enum param 'DataDigest': received 'None,CRC32C', accepted 'None'
9/27 12:03:29.839 fcc Params: <<< Numeric param 'ErrorRecoveryLevel': received 2, accepted 0
9/27 12:03:29.839 fcc Params: <<< Boolean param 'InitialR2T': received No, accepted 0
9/27 12:03:29.839 fcc Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
9/27 12:03:29.839 fcc Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 65536, accepted 65536
9/27 12:03:29.839 fcc Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 65536
9/27 12:03:29.839 fcc Params: <<< Numeric param 'FirstBurstLength': received 65536, accepted 65536
9/27 12:03:29.839 fcc Params: <<< Numeric param 'MaxConnections': received 8, accepted 1
9/27 12:03:29.839 fcc Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
9/27 12:03:29.839 fcc Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
9/27 12:03:29.839 fcc Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 2
9/27 12:03:29.839 fcc Params: <<< Numeric param 'DefaultTime2Retain': received 60, accepted 20
9/27 12:03:29.839 fcc Params: <<< Numeric param 'MaxOutstandingR2T': received 16, accepted 1
9/27 12:03:29.839 fcc Params: >>> ErrorRecoveryLevel=0.
9/27 12:03:29.839 fcc Params: >>> MaxConnections=1.
9/27 12:03:29.839 fcc Params: >>> HeaderDigest=None.
9/27 12:03:29.839 fcc Params: >>> DataDigest=None.
9/27 12:03:29.839 fcc Params: >>> InitialR2T=No.
9/27 12:03:29.839 fcc Params: >>> ImmediateData=Yes.
9/27 12:03:29.839 fcc Params: >>> MaxRecvDataSegmentLength=65536.
9/27 12:03:29.839 fcc Params: >>> MaxBurstLength=65536.
9/27 12:03:29.839 fcc Params: >>> FirstBurstLength=65536.
9/27 12:03:29.839 fcc Params: >>> DefaultTime2Wait=2.
9/27 12:03:29.839 fcc Params: >>> DefaultTime2Retain=20.
9/27 12:03:29.839 fcc Params: >>> MaxOutstandingR2T=1.
9/27 12:03:29.839 fcc Params: >>> DataPDUInOrder=Yes.
9/27 12:03:29.839 fcc Params: >>> DataSequenceInOrder=Yes.
9/27 12:03:29.839 d30 T[1]: session 0xa, connection 0xa : end of stage 1, next stage 3.
9/27 12:03:29.839 d30 C[a], IN_LOGIN: Event - LOGIN_ACCEPT.
9/27 12:03:29.839 d30 C[a], LIN: T5.
9/27 12:16:59.683 ff4 conf: Accepted control connection from 127.0.0.1:1835.
9/27 12:16:59.824 bc0 conf: Auth OK. (client authentificated only)
9/27 12:22:38.699 d30 C[a], LIN: Event - LOGOUT.
9/27 12:22:38.699 d30 C[a], IN_LOGOUT: T9/10.
9/27 12:22:38.699 774 C[a], IN_LOGOUT: Event - LOGOUT_ACCEPT.
9/27 12:22:38.699 774 C[a], FREE: T13.
9/27 12:22:38.699 fcc C[a], FREE: recvData() error (10058)
9/27 12:22:38.699 d30 Tgt: : close 'pc0063': 0 session(s) opened, 1 more allowed.
Hi,mauropgm wrote:and it worked at first time.... boh....mauropgm wrote: i'll try with another 2000 server virtualized...
thankyou!
yes it is. Virtualized on a 64 bit machine (2003 server enterprise x64 with virtual server 2005 r2 sp1 x64 edition) a sbs2003 server guest and a 2000 server sp4 guest worked well.. (once corrected the "maxtransfer size parameter of the initiator)valery (staff) wrote:Hi,mauropgm wrote:and it worked at first time.... boh....mauropgm wrote: i'll try with another 2000 server virtualized...
thankyou!
Do you mean that it works from the virtualized Win2000 machine and fails from the real one?
i didn't try on physical machines, i'm gonna try but i've just entered the registration code, and now i connot make SPTI.valery (staff) wrote: Have you tried doing the same things from a Win XP SP2 or Win 2003 SP1+ machine? Any differences?
There could be some third-party filter driver in the Win2000 host, that prevents it from working.mauropgm wrote:yes it is. Virtualized on a 64 bit machine (2003 server enterprise x64 with virtual server 2005 r2 sp1 x64 edition) a sbs2003 server guest and a 2000 server sp4 guest worked well.. (once corrected the "maxtransfer size parameter of the initiator)
Do you mean that after installing your license, the SPTI module became disabled?i didn't try on physical machines, i'm gonna try but i've just entered the registration code, and now i connot make SPTI. :( :cry:valery (staff) wrote:Have you tried doing the same things from a Win XP SP2 or Win 2003 SP1+ machine? Any differences?
should i reinstall Starwind??
i've downloaded the free version and i've been in evaluation mode...valery (staff) wrote: Do you mean that after installing your license, the SPTI module became disabled?
Does your license a Professional one? The Standard Server license doesnot allow the SPTI module.
