StarWind V2V Converter
Rohit
Mon Nov 16, 2026 2:29 pm
I couldn't find specific information regarding the following:
1. VM limitations: Is there a maximum number of virtual machines that can be converted or exported? Are there any limitations on the total number of conversions?
2. Simultaneous conversions: How many VMs can be converted simultaneously?
3. Virtual disk limitations: Is there a maximum supported virtual disk size?
4. Conversion performance: What factors influence the conversion speed, especially when migrating large VMs?
5. Live migration: Can VMs be converted while they are running without requiring downtime?
6. VM configuration: Are settings such as CPU, RAM, network adapters and disk controllers automatically transferred to the new Hyper-V VM?
7. Snapshots: Are VMware snapshots supported during the conversion process?
8. Data integrity: What measures are in place to ensure that no data is lost or corrupted during migration?
Additionally, are there any other technical limitations or requirements that I should be aware of before using the converter in a production environment?
Mon Nov 16, 2026 3:51 pm
Welcome to StarWind Forum.
No, it is a free product. No limitations.
No simultaneous conversions are allowed in UI. With CLI, you can run several instances for conversion.
No limitations.
V2V is single threaded.
Also, network bandwidth and source and destination storage types impact it.
Yes.
Network adapter and disk controller types need to be assigned. Careful with IDE/SCSI controllers.
Converting disks and recreating VM might be a better idea.
Merge them beforehand.
While V2V supports live conversion, you can shut down the VM to play it super safe. Also, the moment conversion is over, the source VM needs to be shut down, and the destination needs to be started. These procedures are not automated on the V2V side.
Nothing outside what is mentioned above/on this forum.
Good luck with your project.
