Remove-Device does not clear the headers folder
mete
Fri Oct 24, 2025 5:55 am
(Using VTL free)
After adding a new device with Add-VirtualTapeLibrary, removing it with Remove-Device does not remove the folder (created by Add-VirtualTapeLibrary) under StarWind/headers. Is there another function I should use or ?
Fri Oct 24, 2025 7:27 am
This is expected behavior. Feel free to remove it yourself if you don't need it.
