Failed to write block. Error code "665"
Ardelan
Wed Jan 26, 2022 8:02 am
Good morning,
I am useing starwind VTL on a server 2019.
I have a VM with server 2012R2 with DPM, everything works fine except 1 (large, around 6 tb) backup to tape does not work.
After a couple of TB i get this error in DPM 30101 Data error Cyclic redudancy check 0x80070017.
At the same time the following error occurs in VTL:
UID 2068 CODE 4355 Description VTL Device VTL2: TAPE 'xxx" Failed to write block. Error code '665'
Now i am trying the following regfix on the DPM: HKLM\SOFTWARE\Microsoft\Microsoft Data Protection Manager\Agent BufferQueueSize 5 and the backup is running.
In the meanwhile i am open to other suggestions, if the bufferQueueSize regfix fails.
Kind regards
Wed Jan 26, 2022 1:07 pm
Greetings,
Could we kindly have the logs, please? Use log collector to collect them https://knowledgebase.starwindsoftware. ... collector/. Share them with SharePoint or any other convenient tool.
Ardelan
Thu Jan 27, 2022 7:44 am
I have send the link to logs in a PM
Mon Jan 31, 2022 9:37 am
Greetings,
Please consider updating VTL and VSAN to the latest build and reconnecting the tapes over iSCSI. Also make sure to split the tape in parts so that each part is 1 TB. If updating does not help, please send me the logs again and log a call with us at support@starwind.com
