StarWind iSCSI SAN
VTL Free Replicate to Wasabi
Postby jwardlow » Sun Jan 05, 2020 7:36 pm
Running free version of VTL. StarWind Virtual SAN v8.0.0 (Build 13279, [SwSAN], Win64) Veeam backup to tape is running fine, able to use powershell to create, load, move tapes no problem. Modified the supplied VTLReplicationSettings cmdlet to replicate tape to Wasabi. When I run the cmdlet, tape shows as scheduled for upload, then a few seconds later the Starwind service crashes.
Event Log:
Faulting application name: StarWindNVMeoF.exe, version: 1.1.0.4120, time stamp: 0x5c52cd07
Faulting module name: StarWindNVMeoF.exe, version: 1.1.0.4120, time stamp: 0x5c52cd07
Exception code: 0xc0000005
Fault offset: 0x000000000001bf27
Faulting process id: 0x2d4
Faulting application start time: 0x01d5c3f8fc74f64d
Faulting application path: C:\Program Files\StarWind Software\StarWind\StarWindNVMeoF.exe
Faulting module path: C:\Program Files\StarWind Software\StarWind\StarWindNVMeoF.exe
Report Id: 3a36f78f-2fec-11ea-80f3-00155d977904
Faulting package full name:
Faulting package-relative application ID:
Script Settings:
$deviceName="vtl1",
$tapeName="SW419003",
$target=[StarWindVtlReplicationTarget]::REPLICATION_TARGET_WASABI,
$accessKey="*********",
$secretAccessKey="********",
$regionName="us-east-1",
$containerName="swvtl01",
$keepLocal=1,
#$keepInCloud=-1,
#$keepInStorage1=-1,
#$keepInStorage2=-1,
$delayBeforeStart=0,
$serviceUrl="https://s3.wasabisys.com")
$device.UploadTape($tapeName)
#$device.DownloadTape($tapeName) #bb
Note: Also tried $target=[StarWindVtlReplicationTarget]::REPLICATION_TARGET_S3GENERIC,
Same result.
Any help would be appreciated.
jwardlow
Re: VTL Free Replicate to Wasabi
Postby Boris (staff) » Sun Jan 05, 2020 8:38 pm
Try disabling the mentioned service and rerun the steps. That service is not used in your environment anyway.
Postby jwardlow » Sun Jan 05, 2020 10:25 pm
My mistake. The first service to fail is the Starwind service. Obviously that one is used.
Faulting application name: StarWindService.exe, version: 8.0.0.13279, time stamp: 0x5da5c9c6
Faulting module name: VTL.dll, version: 8.0.0.13279, time stamp: 0x5da5c90a
Exception code: 0xc0000409
Fault offset: 0x00000000000d8828
Faulting process id: 0x138
Faulting application start time: 0x01d5c3f6f527d932
Faulting application path: C:\Program Files\StarWind Software\StarWind\StarWindService.exe
Faulting module path: C:\Program Files\StarWind Software\StarWind\VTL.dll
Report Id: e92cbb32-2feb-11ea-80f3-00155d977904
jwardlow
Postby Boris (staff) » Mon Jan 06, 2020 7:50 am
Could you collect the logs from your system using StarWind Log Collector and submit them to us?
Postby jwardlow » Mon Jan 06, 2020 4:13 pm
Submitted to support with reference to this posting.
jwardlow
Postby Boris (staff) » Fri Jan 10, 2020 3:10 pm
Communication will be done via the corresponding ticket. We will update the community when it's resolved.
Postby Boris (staff) » Wed Jan 22, 2020 2:52 pm
The issue was due to a very big number of parts the tape was broken into at the moment of tape creation. To avoid this, make sure to create a tape either as a solid one or break it into bigger parts (gigabytes or dozens of GB).
Return to StarWind Virtual Tape Library (VTL) & StarWind VTL Free, StarWind VTL Appliance
Who is online
