How to delete tapes
kdavenport
Wed Oct 03, 2018 1:39 am
We are evaluating the VTL software with Veeam and have successfully created a job to copy a backup job to a virtual tape and migrate it to an S3 bucket upon exporting the tape from the VTL.
Question: How do you delete a tape from the offline shelf? I can manually remove the tape from S3 but the cloud status in the Starwind console does not change.
Oleg(staff)
Thu Oct 04, 2018 9:06 am
This option should be added in the nearest time with the new release.
mga
Fri Jan 24, 2020 3:38 pm
Hi There,
Is there any progess on this feature? Is it implemented also in the free edition?
We also testing StarWind VTL free as an offsite backup solution whereas now we have tons of VTLs on the Offline Shelf after our tests. Is there way in the free edition via PowerShell to clean them up?
Thank you in advance!
Michael (staff)
Thu Feb 06, 2020 9:18 pm
We are currently working on this possibility for the free version. It will be available in the next builds.
mga
Fri Feb 07, 2020 9:39 am
Thank you very much!
Fri Feb 07, 2020 9:50 am
You are welcome, stay tuned.
Michael (staff)
Sat Oct 17, 2020 5:12 pm
Hello everyone, the fix shoudl be present in the build 13861.
schwarzalex68
Tue Jan 12, 2021 10:28 am
this fix would be very helpful. I will be glad if there is news about it :)
Tue Jan 12, 2021 11:47 am
Hey, the fix is already in 13861, the latest StarWind VSAN build.
Joseph93
Thu Jan 28, 2021 7:42 am
Thank you very much! I didn't know it
nathangamer
Mon Apr 26, 2021 10:55 am
I didn't know this update already existed either. Very cool, thank you
Mon Apr 26, 2021 11:40 am
You are welcome. You can always check the release notes at https://www.starwindsoftware.com/release-notes-build.
