StarWind iSCSI SAN
Error Formating VTL On HP Data Protector
StarWind VTL / VTL Appliance / Storage Gateway for Backblaze
Postby bench3 » Thu Mar 03, 2016 8:29 am
I am getting the below error when trying to format the VTL on HP Data protector.
I hope someone from the technical team can give me a solution to this.
[Normal] From: [email protected] "StarWind:Virtual Tape_smaserv(2)" Time: 3/3/2016 12:01:29 PM
scsi7:0:0:0C
Initializing new medium: "Default Tape_4"
[Major] From: [email protected] "StarWind:Virtual Tape_smaserv(2)" Time: 3/3/2016 12:01:30 PM
[90:51] scsi7:0:0:0C
Cannot write to device (Details unknown.)
Initialization of medium failed.
Thanks and Regards,
bench3
Re: Error Formating VTL On HP Data Protector
Postby bench3 » Thu Mar 03, 2016 8:36 am
And when i load the virtual tape in to the VTL, am getting the below message. I am still trying to do add my first virtual tape drive and disk. Appreciate if some one can guide me on how to setup VTL.
[Normal] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:34:12 PM
Media session 2016/03/03-54 started.
STARTING Media Agent "StarWind:Virtual Tape_smaserver"
[Warning] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:34:12 PM
The device "StarWind:Virtual Tape_smaserver" could not be opened("Device could not be accessed")
Starting the device path discovery process.
[Normal] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:34:13 PM
A new path(s) "scsi7:0:3:0C" found for device "StarWind:Virtual Tape_smaserver" and stored.
Device path discovery process finished.
[Warning] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:34:13 PM
[90:123] scsi7:0:3:0C
Unknown device, please check device support matrix
[Major] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:41:04 PM
[90:54] scsi7:0:3:0C
Cannot open device (Unit not ready.)
[Normal] From: [email protected] "StarWind:Virtual Tape_smaserver" Time: 3/3/2016 1:41:04 PM
ABORTED Media Agent "StarWind:Virtual Tape_smaserver"
0 media out of 1 successfully initialized.
bench3
Postby bench3 » Fri Mar 04, 2016 5:20 am
anyone there to solve this?
I am using HP Data protector 6 Build April 2009, on HP Storage Server
bench3
Postby Vladislav (Staff) » Fri Mar 04, 2016 11:23 am
Hello bench3,
Have you installed the latest HP Store Ever drivers on StarWind VTL host as well as on the client host running Data Protector software?
It would be great to see your network diagram as well :)
Vladislav (Staff)
Postby bench3 » Fri Mar 04, 2016 12:10 pm
Thanks Vladislav,
I have not installed the HPStore Ever Drivers, let me check that. And about the network diagram, will update soon.
bench3
Postby Anatoly (staff) » Wed Mar 09, 2016 7:05 pm
@Bench, do you have any update for us please?
[email protected]
Postby bench3 » Tue Apr 26, 2016 4:24 pm
I am still not able to install the VTL on my windows server 2003 Storage Server with HP Data Protector,
I also tried the same on WIndows Server 2012 running Symantec Backup Exec 15. We have no idea how this is going to work, there is no driver, and the device manager only detects the tape as "Other Devices"...
WIthout drivers, we will not be in a position to try your products. And i dont mind much support from your team.
bench3
Postby Dmitry (staff) » Wed May 04, 2016 10:20 am
Hello Bench,
Could you clarify what StarWind version you are using?
As you can see from our system requirements, StarWind V8 supports from Windows Server 2008 R2 to Windows Server 2012 R2
Dmitry (staff)
Postby merrywatson » Mon Jan 28, 2019 6:31 am
The problem may, in fact, be caused by the Windows Update problem. You can do one thing, i,e, update the Windows and then restart the system. You can also check the Windows status. If it is not satisfactory, then reset the Windows following the steps given on Windows update error code 8007000e and get a better service from the system.
merrywatson
Postby Oleg(staff) » Mon Jan 28, 2019 11:42 am
That is an actual old thread but thank you for sharing the solution.
Oleg(staff)
Return to StarWind VTL / VTL Appliance / Storage Gateway for Backblaze
Who is online
