VTL compression?
ireneshultz
Sat Sep 05, 2015 6:16 am
Can you share a bit more information about compression and deduplication you use with VTL? Any estimates on savings? Thanks!
Tue Sep 15, 2015 10:57 pm
Sure thing! Basically, you need to enable the MS deduplication on the volume where StarWind VTL is located. So basically we are refering to the dedup ratio of Ms in case of cold data. This link should be helpful here:
http://blogs.technet.com/b/filecab/arch ... -2012.aspx
Tue Jan 19, 2016 7:34 am
Just a tiny update here: I'd suggest to take a look at our hardware VTL appliance as it has all the deduplication / compression settings applied out-of-box. Here:
https://www.starwindsoftware.com/starwi ... pe-library
Good luck! :)
