Deduplication / compression?
noomi
Wed Mar 25, 2015 7:32 am
Do you have any plans to support deduplication and / or compression with your virtual tapes? StarWind has dedupe in disks?
imrna
Thu Mar 26, 2015 9:53 pm
Actually deduplicating the data that is on StarWind VTl drive is possible.
StarWind VTL drive runs on top of the Windows, thus it is possible to enable MS Deduplication on the partition where VTL files reside, thus all the backups will be compressed.
Fri Mar 27, 2015 11:14 am
Hi! just a quick check - anything else that we may help you with?
