Starwind VTL and 2008R2
trevor-austin
Tue Jul 03, 2012 1:01 pm
I have followed the documentation to trial the VTL capability and have attached to the iscsi connection.
In 2008R2 this then gives an 'other' device with the correct name but a blue question mark and is not seeing it as a tape drive. If I scan for tape drives with DPM it cannot see this device either.
Any help appreciated as this is to go into a live environment and replace firestreamer which is not working if it works.
Trevor
Tue Jul 03, 2012 1:56 pm
Have you installed the VTL driver? if not please use the link below to download it
http://www.starwindsoftware.com/Zd23x67 ... Driver.exe
trevor-austin
Tue Jul 03, 2012 2:10 pm
That appears to have sorted it thanks
trevor-austin
Tue Jul 03, 2012 2:45 pm
DPM is now seeing the device and I have followed your PDF on DPM adding and using tape drives.
I inventoried the drive, then identified it then cleaned it and got the warnings but nothing actually appears to be happening? This is with DPM 2010?
Thu Jul 05, 2012 9:27 am
Just a little udate for the community: we had a conversation with Trevor. currently he promissed to get back to me if he`ll have any questions and we agreed that this is something with DPM.
