Connecting 2 hosts to iSCSI target free edition
Awx
Sun Jun 10, 2012 9:43 pm
Hi all
I have 2 x vsphere 4.1 hosts connecting to a server 2003 starwind server for shared storage. The first host finds the iSCSI target fine and I have created the datastores within vcenter but the 2nd host cannot see the starwind iSCSI target on re-scan at all.
Am I right in thinking that the free version of the software supports more than one host connecting to it simultaneously or is there some extra configuration I am missing?
Many thanks
AW
Sun Jun 10, 2012 9:54 pm
Yes, should be working just fine unless you've did something wrong. Please try to re-connect and send us StarWind log so we could tell for sure what's broken. Thank you!
Awx
Mon Jun 11, 2012 9:20 pm
Hi Anton
Thanks for the reply. A section of the logfile is below :
Cheers
Andy
6/11 21:00:22.265 360 Srv: Accepted iSCSI connection from 192.168.100.30:58762 to 192.168.100.60:3260. (Id = 0x7)
6/11 21:00:22.265 360 C[7], FREE: Event - CONNECTED.
6/11 21:00:22.265 360 C[7], XPT_UP: T3.
6/11 21:00:22.265 5ec C[7], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 21:00:22.265 5ec C[7], XPT_UP: Event - LOGIN.
6/11 21:00:22.265 5ec C[7], IN_LOGIN: T4.
6/11 21:00:22.265 5ec Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:22.265 5ec Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 21:00:22.265 5ec Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:22.265 5ec Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:22.265 5ec Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 21:00:22.265 5ec Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:22.265 5ec Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:22.265 5ec Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:22.265 5ec Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:22.265 5ec Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 21:00:22.265 5ec Params: >>> ErrorRecoveryLevel=0.
6/11 21:00:22.265 5ec Params: >>> HeaderDigest=None.
6/11 21:00:22.265 5ec Params: >>> DataDigest=None.
6/11 21:00:22.265 5ec Params: >>> OFMarker=No.
6/11 21:00:22.265 5ec Params: >>> IFMarker=No.
6/11 21:00:22.265 5ec Params: >>> InitialR2T=No.
6/11 21:00:22.265 5ec Params: >>> ImmediateData=Yes.
6/11 21:00:22.265 5ec Params: >>> MaxRecvDataSegmentLength=262144.
6/11 21:00:22.265 5ec Params: >>> MaxBurstLength=262144.
6/11 21:00:22.265 5ec Params: >>> FirstBurstLength=262144.
6/11 21:00:22.265 5ec Params: >>> DefaultTime2Wait=0.
6/11 21:00:22.265 5ec Params: >>> DefaultTime2Retain=0.
6/11 21:00:22.265 5ec Params: >>> MaxOutstandingR2T=1.
6/11 21:00:22.265 5ec Params: >>> DataPDUInOrder=Yes.
6/11 21:00:22.265 5ec Params: >>> DataSequenceInOrder=Yes.
6/11 21:00:22.265 678 T[7,1]: session 0x7, connection 0x7 : end of stage 1, next stage 3.
6/11 21:00:22.265 678 C[7], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 21:00:22.265 678 C[7], LIN: T5.
6/11 21:00:22.281 678 C[7], LIN: Event - LOGOUT.
6/11 21:00:22.281 678 C[7], IN_LOGOUT: T9/10.
6/11 21:00:22.281 510 C[7], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 21:00:22.281 510 C[7], FREE: T13.
6/11 21:00:22.281 5ec C[7], FREE: recvData returned 10054
6/11 21:00:22.296 360 Srv: Accepted iSCSI connection from 192.168.100.30:55775 to 192.168.100.60:3260. (Id = 0x8)
6/11 21:00:22.296 360 C[8], FREE: Event - CONNECTED.
6/11 21:00:22.296 360 C[8], XPT_UP: T3.
6/11 21:00:22.312 360 Srv: Accepted iSCSI connection from 192.168.100.30:61430 to 192.168.100.60:3260. (Id = 0x9)
6/11 21:00:22.312 360 C[9], FREE: Event - CONNECTED.
6/11 21:00:22.312 360 C[9], XPT_UP: T3.
6/11 21:00:22.328 360 Srv: Accepted iSCSI connection from 192.168.100.30:60079 to 192.168.100.60:3260. (Id = 0xa)
6/11 21:00:22.328 360 C[a], FREE: Event - CONNECTED.
6/11 21:00:22.328 360 C[a], XPT_UP: T3.
6/11 21:00:22.578 bc4 C[8], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:22.578 bc4 C[8], XPT_UP: Event - LOGIN.
6/11 21:00:22.578 bc4 C[8], IN_LOGIN: T4.
6/11 21:00:22.578 bc4 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:22.578 bc4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'
6/11 21:00:22.578 bc4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:22.578 bc4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:22.578 bc4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:22.578 cbc C[9], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:22.578 bc4 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:22.578 bc4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:22.578 cbc C[9], XPT_UP: Event - LOGIN.
6/11 21:00:22.578 cbc C[9], IN_LOGIN: T4.
6/11 21:00:22.578 368 C[a], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:22.578 cbc Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:22.578 cbc Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'
6/11 21:00:22.578 cbc Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:22.578 cbc Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:22.578 cbc Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:22.578 cbc Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:22.578 cbc Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:22.578 cbc Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:22.578 cbc Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:22.578 cbc Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:22.578 cbc Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:22.578 cbc Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:22.578 cbc Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 cbc Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 cbc Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:22.578 cbc Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:22.578 cbc Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:22.578 cbc Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:22.578 cbc Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:22.578 368 C[a], XPT_UP: Event - LOGIN.
6/11 21:00:22.578 368 C[a], IN_LOGIN: T4.
6/11 21:00:22.578 368 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:22.578 368 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'
6/11 21:00:22.578 368 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:22.578 368 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:22.578 368 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:22.578 368 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:22.578 368 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:22.578 368 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:22.578 368 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:22.578 368 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:22.578 368 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:22.578 368 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:22.578 368 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 368 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:22.578 368 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:22.578 368 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:22.578 368 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:22.578 368 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:22.578 368 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:22.578 368 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: all of 1 allowed sessions are opened!
6/11 21:00:22.578 368 T[a,1]: *ERROR* Login request: device open failed.
6/11 21:00:22.578 cbc Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: all of 1 allowed sessions are opened!
6/11 21:00:22.578 cbc T[9,1]: *ERROR* Login request: device open failed.
6/11 21:00:22.578 bc4 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: all of 1 allowed sessions are opened!
6/11 21:00:22.578 bc4 T[8,1]: *ERROR* Login request: device open failed.
6/11 21:00:22.578 c70 C[9], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:22.578 6d8 C[a], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:22.578 c70 C[9], FREE: T7.
6/11 21:00:22.578 6d8 C[a], FREE: T7.
6/11 21:00:22.578 67c C[8], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:22.578 67c C[8], FREE: T7.
6/11 21:00:22.828 368 C[a], FREE: recvData returned 10058
6/11 21:00:22.828 cbc C[9], FREE: recvData returned 10058
6/11 21:00:22.843 bc4 C[8], FREE: recvData returned 10058
6/11 21:00:23.328 360 Srv: Accepted iSCSI connection from 192.168.100.30:59697 to 192.168.100.60:3260. (Id = 0xb)
6/11 21:00:23.328 360 C, FREE: Event - CONNECTED.
6/11 21:00:23.328 360 C, XPT_UP: T3.
6/11 21:00:23.328 818 C, XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 21:00:23.328 818 C, XPT_UP: Event - LOGIN.
6/11 21:00:23.328 818 C, IN_LOGIN: T4.
6/11 21:00:23.328 818 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:23.328 818 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 21:00:23.328 818 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:23.328 818 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:23.328 818 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 21:00:23.328 818 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:23.328 818 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:23.328 818 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:23.328 818 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:23.328 818 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 21:00:23.328 818 Params: >>> ErrorRecoveryLevel=0.
6/11 21:00:23.328 818 Params: >>> HeaderDigest=None.
6/11 21:00:23.328 818 Params: >>> DataDigest=None.
6/11 21:00:23.328 818 Params: >>> OFMarker=No.
6/11 21:00:23.328 818 Params: >>> IFMarker=No.
6/11 21:00:23.328 818 Params: >>> InitialR2T=No.
6/11 21:00:23.328 818 Params: >>> ImmediateData=Yes.
6/11 21:00:23.328 818 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 21:00:23.328 818 Params: >>> MaxBurstLength=262144.
6/11 21:00:23.328 818 Params: >>> FirstBurstLength=262144.
6/11 21:00:23.328 818 Params: >>> DefaultTime2Wait=0.
6/11 21:00:23.328 818 Params: >>> DefaultTime2Retain=0.
6/11 21:00:23.328 818 Params: >>> MaxOutstandingR2T=1.
6/11 21:00:23.328 818 Params: >>> DataPDUInOrder=Yes.
6/11 21:00:23.328 818 Params: >>> DataSequenceInOrder=Yes.
6/11 21:00:23.343 7e0 T[b,1]: session 0xb, connection 0xb : end of stage 1, next stage 3.
6/11 21:00:23.343 7e0 C, IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 21:00:23.343 7e0 C, LIN: T5.
6/11 21:00:23.343 7e0 C, LIN: Event - LOGOUT.
6/11 21:00:23.343 7e0 C, IN_LOGOUT: T9/10.
6/11 21:00:23.343 5a8 C, IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 21:00:23.343 5a8 C[b], FREE: T13.
6/11 21:00:23.343 818 C[b], FREE: recvData returned 10054
6/11 21:00:23.375 360 Srv: Accepted iSCSI connection from 192.168.100.30:49884 to 192.168.100.60:3260. (Id = 0xc)
6/11 21:00:23.375 360 C[c], FREE: Event - CONNECTED.
6/11 21:00:23.375 360 C[c], XPT_UP: T3.
6/11 21:00:23.375 360 Srv: Accepted iSCSI connection from 192.168.100.30:49457 to 192.168.100.60:3260. (Id = 0xd)
6/11 21:00:23.375 360 C[d], FREE: Event - CONNECTED.
6/11 21:00:23.375 360 C[d], XPT_UP: T3.
6/11 21:00:23.390 360 Srv: Accepted iSCSI connection from 192.168.100.30:54997 to 192.168.100.60:3260. (Id = 0xe)
6/11 21:00:23.390 360 C[e], FREE: Event - CONNECTED.
6/11 21:00:23.390 360 C[e], XPT_UP: T3.
6/11 21:00:23.640 1f8 C[c], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:23.640 1f8 C[c], XPT_UP: Event - LOGIN.
6/11 21:00:23.640 1f8 C[c], IN_LOGIN: T4.
6/11 21:00:23.640 1f8 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:23.640 1f8 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'
6/11 21:00:23.640 1f8 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:23.640 1f8 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:23.640 1f8 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:23.640 ac0 C[d], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:23.640 1f8 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:23.640 1f8 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:23.640 ac0 C[d], XPT_UP: Event - LOGIN.
6/11 21:00:23.640 ac0 C[d], IN_LOGIN: T4.
6/11 21:00:23.640 ac0 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:23.640 c30 C[e], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:23.640 ac0 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'
6/11 21:00:23.640 ac0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:23.640 ac0 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:23.640 ac0 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:23.640 ac0 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:23.640 ac0 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:23.640 c30 C[e], XPT_UP: Event - LOGIN.
6/11 21:00:23.640 c30 C[e], IN_LOGIN: T4.
6/11 21:00:23.640 c30 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:23.640 c30 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'
6/11 21:00:23.640 c30 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:23.640 c30 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:23.640 c30 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:23.640 c30 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:23.640 c30 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:23.640 c30 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:23.640 c30 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:23.640 c30 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:23.640 c30 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:23.640 c30 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:23.640 c30 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 c30 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:23.640 c30 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:23.640 c30 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:23.640 c30 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:23.640 c30 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:23.640 c30 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:23.640 ac0 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: all of 1 allowed sessions are opened!
6/11 21:00:23.640 ac0 T[d,1]: *ERROR* Login request: device open failed.
6/11 21:00:23.640 1f8 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: all of 1 allowed sessions are opened!
6/11 21:00:23.640 1f8 T[c,1]: *ERROR* Login request: device open failed.
6/11 21:00:23.640 9f0 C[c], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:23.640 9f0 C[c], FREE: T7.
6/11 21:00:23.640 a34 C[d], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:23.640 a34 C[d], FREE: T7.
6/11 21:00:23.640 c30 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: all of 1 allowed sessions are opened!
6/11 21:00:23.640 c30 T[e,1]: *ERROR* Login request: device open failed.
6/11 21:00:23.640 bb4 C[e], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:23.640 bb4 C[e], FREE: T7.
6/11 21:00:23.890 1f8 C[c], FREE: recvData returned 10058
6/11 21:00:23.906 ac0 C[d], FREE: recvData returned 10058
6/11 21:00:23.906 c30 C[e], FREE: recvData returned 10058
6/11 21:00:34.296 360 Srv: Accepted iSCSI connection from 192.168.100.30:57023 to 192.168.100.60:3260. (Id = 0xf)
6/11 21:00:34.296 360 C[f], FREE: Event - CONNECTED.
6/11 21:00:34.296 360 C[f], XPT_UP: T3.
6/11 21:00:34.296 e88 C[f], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 21:00:34.296 e88 C[f], XPT_UP: Event - LOGIN.
6/11 21:00:34.296 e88 C[f], IN_LOGIN: T4.
6/11 21:00:34.296 e88 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:34.296 e88 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 21:00:34.296 e88 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:34.296 e88 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:34.296 e88 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 21:00:34.296 e88 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:34.296 e88 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:34.296 e88 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:34.296 e88 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:34.296 e88 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 21:00:34.296 e88 Params: >>> ErrorRecoveryLevel=0.
6/11 21:00:34.296 e88 Params: >>> HeaderDigest=None.
6/11 21:00:34.296 e88 Params: >>> DataDigest=None.
6/11 21:00:34.296 e88 Params: >>> OFMarker=No.
6/11 21:00:34.296 e88 Params: >>> IFMarker=No.
6/11 21:00:34.296 e88 Params: >>> InitialR2T=No.
6/11 21:00:34.296 e88 Params: >>> ImmediateData=Yes.
6/11 21:00:34.296 e88 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 21:00:34.296 e88 Params: >>> MaxBurstLength=262144.
6/11 21:00:34.296 e88 Params: >>> FirstBurstLength=262144.
6/11 21:00:34.296 e88 Params: >>> DefaultTime2Wait=0.
6/11 21:00:34.296 e88 Params: >>> DefaultTime2Retain=0.
6/11 21:00:34.296 e88 Params: >>> MaxOutstandingR2T=1.
6/11 21:00:34.296 e88 Params: >>> DataPDUInOrder=Yes.
6/11 21:00:34.296 e88 Params: >>> DataSequenceInOrder=Yes.
6/11 21:00:34.296 108 T[f,1]: session 0xf, connection 0xf : end of stage 1, next stage 3.
6/11 21:00:34.296 108 C[f], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 21:00:34.296 108 C[f], LIN: T5.
6/11 21:00:34.312 108 C[f], LIN: Event - LOGOUT.
6/11 21:00:34.312 108 C[f], IN_LOGOUT: T9/10.
6/11 21:00:34.312 cb0 C[f], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 21:00:34.312 cb0 C[f], FREE: T13.
6/11 21:00:34.312 e88 C[f], FREE: recvData returned 10054
6/11 21:00:34.343 360 Srv: Accepted iSCSI connection from 192.168.100.30:56801 to 192.168.100.60:3260. (Id = 0x10)
6/11 21:00:34.343 360 C[10], FREE: Event - CONNECTED.
6/11 21:00:34.343 360 C[10], XPT_UP: T3.
6/11 21:00:34.343 360 Srv: Accepted iSCSI connection from 192.168.100.30:50762 to 192.168.100.60:3260. (Id = 0x11)
6/11 21:00:34.343 360 C[11], FREE: Event - CONNECTED.
6/11 21:00:34.343 360 C[11], XPT_UP: T3.
6/11 21:00:34.359 360 Srv: Accepted iSCSI connection from 192.168.100.30:61165 to 192.168.100.60:3260. (Id = 0x12)
6/11 21:00:34.359 360 C[12], FREE: Event - CONNECTED.
6/11 21:00:34.359 360 C[12], XPT_UP: T3.
6/11 21:00:34.609 d40 C[10], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:34.609 d40 C[10], XPT_UP: Event - LOGIN.
6/11 21:00:34.609 d40 C[10], IN_LOGIN: T4.
6/11 21:00:34.609 d40 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:34.609 d40 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'
6/11 21:00:34.609 d40 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:34.609 d40 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:34.609 d40 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:34.609 d40 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:34.609 d40 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:34.609 d50 C[11], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:34.609 d40 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:34.609 d40 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:34.609 d40 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:34.609 d40 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:34.609 d40 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:34.609 d40 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 d40 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 d40 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:34.609 d40 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:34.609 d40 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:34.609 d40 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:34.609 d40 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:34.609 d50 C[11], XPT_UP: Event - LOGIN.
6/11 21:00:34.609 d50 C[11], IN_LOGIN: T4.
6/11 21:00:34.609 d50 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:34.609 d50 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'
6/11 21:00:34.609 150 C[12], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:00:34.609 d50 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:34.609 d50 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:34.609 d50 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:34.609 d50 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:34.609 d50 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:34.609 d50 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:34.609 d50 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:34.609 d50 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:34.609 d50 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:34.609 d50 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:34.609 d50 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 d50 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 d50 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:34.609 d50 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:34.609 d50 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:34.609 d50 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:34.609 d50 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:34.609 150 C[12], XPT_UP: Event - LOGIN.
6/11 21:00:34.609 150 C[12], IN_LOGIN: T4.
6/11 21:00:34.609 150 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:00:34.609 150 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'
6/11 21:00:34.609 150 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:00:34.609 150 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:00:34.609 150 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:00:34.609 150 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:00:34.609 150 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:00:34.609 150 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:00:34.609 150 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:00:34.609 150 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:00:34.609 150 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:00:34.609 150 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:00:34.609 150 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 150 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:00:34.609 150 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:00:34.609 150 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:00:34.609 150 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:00:34.609 150 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:00:34.609 150 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:00:34.609 d50 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: all of 1 allowed sessions are opened!
6/11 21:00:34.609 d50 T[11,1]: *ERROR* Login request: device open failed.
6/11 21:00:34.609 d54 C[11], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:34.609 d54 C[11], FREE: T7.
6/11 21:00:34.609 150 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: all of 1 allowed sessions are opened!
6/11 21:00:34.609 150 T[12,1]: *ERROR* Login request: device open failed.
6/11 21:00:34.609 d40 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: all of 1 allowed sessions are opened!
6/11 21:00:34.609 d40 T[10,1]: *ERROR* Login request: device open failed.
6/11 21:00:34.609 d48 C[12], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:34.609 d48 C[12], FREE: T7.
6/11 21:00:34.609 b90 C[10], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:00:34.609 b90 C[10], FREE: T7.
6/11 21:00:34.859 d50 C[11], FREE: recvData returned 10058
6/11 21:00:34.875 150 C[12], FREE: recvData returned 10058
6/11 21:00:34.875 d40 C[10], FREE: recvData returned 10058
6/11 21:02:05.421 360 Srv: Accepted iSCSI connection from 192.168.100.30:51160 to 192.168.100.60:3260. (Id = 0x13)
6/11 21:02:05.421 360 C[13], FREE: Event - CONNECTED.
6/11 21:02:05.421 360 C[13], XPT_UP: T3.
6/11 21:02:05.421 200 C[13], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 21:02:05.421 200 C[13], XPT_UP: Event - LOGIN.
6/11 21:02:05.421 200 C[13], IN_LOGIN: T4.
6/11 21:02:05.421 200 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:02:05.421 200 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 21:02:05.421 200 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:02:05.421 200 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:02:05.421 200 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 21:02:05.421 200 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:02:05.421 200 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:02:05.421 200 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:02:05.421 200 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:02:05.421 200 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 21:02:05.421 200 Params: >>> ErrorRecoveryLevel=0.
6/11 21:02:05.421 200 Params: >>> HeaderDigest=None.
6/11 21:02:05.421 200 Params: >>> DataDigest=None.
6/11 21:02:05.421 200 Params: >>> OFMarker=No.
6/11 21:02:05.421 200 Params: >>> IFMarker=No.
6/11 21:02:05.421 200 Params: >>> InitialR2T=No.
6/11 21:02:05.421 200 Params: >>> ImmediateData=Yes.
6/11 21:02:05.421 200 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 21:02:05.421 200 Params: >>> MaxBurstLength=262144.
6/11 21:02:05.421 200 Params: >>> FirstBurstLength=262144.
6/11 21:02:05.421 200 Params: >>> DefaultTime2Wait=0.
6/11 21:02:05.421 200 Params: >>> DefaultTime2Retain=0.
6/11 21:02:05.421 200 Params: >>> MaxOutstandingR2T=1.
6/11 21:02:05.421 200 Params: >>> DataPDUInOrder=Yes.
6/11 21:02:05.421 200 Params: >>> DataSequenceInOrder=Yes.
6/11 21:02:05.421 c94 T[13,1]: session 0x13, connection 0x13 : end of stage 1, next stage 3.
6/11 21:02:05.421 c94 C[13], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 21:02:05.421 c94 C[13], LIN: T5.
6/11 21:02:05.437 c94 C[13], LIN: Event - LOGOUT.
6/11 21:02:05.437 c94 C[13], IN_LOGOUT: T9/10.
6/11 21:02:05.437 284 C[13], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 21:02:05.437 284 C[13], FREE: T13.
6/11 21:02:05.437 200 C[13], FREE: recvData returned 10054
6/11 21:02:05.468 360 Srv: Accepted iSCSI connection from 192.168.100.30:61542 to 192.168.100.60:3260. (Id = 0x14)
6/11 21:02:05.468 360 C[14], FREE: Event - CONNECTED.
6/11 21:02:05.468 360 C[14], XPT_UP: T3.
6/11 21:02:05.484 360 Srv: Accepted iSCSI connection from 192.168.100.30:56397 to 192.168.100.60:3260. (Id = 0x15)
6/11 21:02:05.484 360 C[15], FREE: Event - CONNECTED.
6/11 21:02:05.484 360 C[15], XPT_UP: T3.
6/11 21:02:05.484 360 Srv: Accepted iSCSI connection from 192.168.100.30:51085 to 192.168.100.60:3260. (Id = 0x16)
6/11 21:02:05.484 360 C[16], FREE: Event - CONNECTED.
6/11 21:02:05.484 360 C[16], XPT_UP: T3.
6/11 21:02:05.734 fa4 C[14], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:02:05.734 fa4 C[14], XPT_UP: Event - LOGIN.
6/11 21:02:05.734 fa4 C[14], IN_LOGIN: T4.
6/11 21:02:05.734 fa4 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:02:05.734 fa4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'
6/11 21:02:05.734 fa4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:02:05.734 fa4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:02:05.734 fa4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:02:05.734 cb4 C[15], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:02:05.734 fa4 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:02:05.734 fa4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:02:05.734 cc0 C[16], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 21:02:05.734 cb4 C[15], XPT_UP: Event - LOGIN.
6/11 21:02:05.734 cb4 C[15], IN_LOGIN: T4.
6/11 21:02:05.734 cb4 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:02:05.734 cb4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'
6/11 21:02:05.734 cb4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:02:05.734 cb4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:02:05.734 cb4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:02:05.734 cb4 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:02:05.734 cb4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:02:05.734 cc0 C[16], XPT_UP: Event - LOGIN.
6/11 21:02:05.734 cc0 C[16], IN_LOGIN: T4.
6/11 21:02:05.734 cc0 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-02-719e38e8', accepted 'iqn.1998-01.com.vmware:vshost-02-719e38e8'
6/11 21:02:05.734 cc0 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'
6/11 21:02:05.734 cc0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 21:02:05.734 cc0 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 21:02:05.734 cc0 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 21:02:05.734 cc0 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 21:02:05.734 cc0 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 21:02:05.734 cb4 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: all of 1 allowed sessions are opened!
6/11 21:02:05.734 cb4 T[15,1]: *ERROR* Login request: device open failed.
6/11 21:02:05.734 fa4 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: all of 1 allowed sessions are opened!
6/11 21:02:05.750 fa4 T[14,1]: *ERROR* Login request: device open failed.
6/11 21:02:05.750 c68 C[14], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:02:05.750 c68 C[14], FREE: T7.
6/11 21:02:05.750 164 C[15], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:02:05.750 164 C[15], FREE: T7.
6/11 21:02:05.750 cc0 Tgt: *LIMIT* iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: all of 1 allowed sessions are opened!
6/11 21:02:05.750 cc0 T[16,1]: *ERROR* Login request: device open failed.
6/11 21:02:05.750 cb8 C[16], IN_LOGIN: Event - LOGIN_REJECT.
6/11 21:02:05.750 cb8 C[16], FREE: T7.
6/11 21:02:06.000 fa4 C[14], FREE: recvData returned 10058
6/11 21:02:06.000 cb4 C[15], FREE: recvData returned 10058
6/11 21:02:06.000 cc0 C[16], FREE: recvData returned 10058
Awx
Mon Jun 11, 2012 9:25 pm
Here's the rest of the logfile :
The log file name: 'logs\starwind-20120611-195936.log'
6/11 19:59:36.546 360 Srv: StarWind iSCSI SAN Software v5.8.0 (Build 20120417, [SwSAN], Win32)
6/11 19:59:36.546 360 Srv: Built Apr 17 2012 16:22:52
6/11 19:59:36.546 360 Srv: Windows Server 2003, Standard Edition Service Pack 2 (Build 3790)
6/11 19:59:36.546 360 Srv: System CPU count: 2
6/11 19:59:36.546 360 Srv: CPU affinity mask 0x3 from 0x3.
6/11 19:59:36.578 360 Srv: Licensed to: 'Andrew Woods', 'City COllege', (#2, 0, 80200000, 0).
6/11 19:59:36.578 360 Srv: Config file: 'StarWind.cfg'
6/11 19:59:37.343 360 conf: Variable 'LogLevel' is set to '1'.
6/11 19:59:37.343 360 conf: Variable 'LogMask' is set to '0x8fffffff'.
6/11 19:59:37.343 360 conf: Variable 'UpdatePeriod' is set to '7'.
6/11 19:59:37.343 360 conf: Variable 'UpdateHost' is set to 'www.starwindsoftware.com'.
6/11 19:59:37.343 360 conf: Variable 'UpdatePage' is set to '/updatetracker/index.php'.
6/11 19:59:37.343 360 conf: Variable 'UpdatePort' is set to '80'.
6/11 19:59:37.343 360 conf: Variable 'UpdateCopyId' is set to 'EA935F61-1974-4CF8-A4ABEADF3A56C1F2'.
6/11 19:59:37.343 360 conf: Variable 'UpdateLastRequest' is set to '20120604'.
6/11 19:59:37.343 360 conf: Variable 'Port' is set to '3260'.
6/11 19:59:37.343 360 conf: Variable 'Interface' is set to '0.0.0.0'.
6/11 19:59:37.343 360 conf: Variable 'BCastEnable' is set to 'yes'.
6/11 19:59:37.343 360 conf: Variable 'BCastInterface' is set to '0.0.0.0'.
6/11 19:59:37.343 360 conf: Variable 'BCastPort' is set to '3261'.
6/11 19:59:37.343 360 conf: Variable 'Login' is set to 'root'.
6/11 19:59:37.343 360 conf: Variable 'Password' is set to '##evVRsIJtRmAEEd2sCslZDg=='.
6/11 19:59:37.343 360 conf: Variable 'MinBufferSize' is set to '65536'.
6/11 19:59:37.343 360 conf: Variable 'AlignmentMask' is set to '0x0000'.
6/11 19:59:37.343 360 conf: Variable 'MaxPendingRequests' is set to '64'.
6/11 19:59:37.343 360 conf: Variable 'iScsiPingPeriod' is set to '0'.
6/11 19:59:37.343 360 conf: Variable 'LocalizationDir' is set to 'Localizations'.
6/11 19:59:37.343 360 conf: Variable 'DataBaseRoot' is set to '.\NotifyDB'.
6/11 19:59:37.343 360 conf: Invalid variable 'DBRotationDays'.
6/11 19:59:37.343 360 conf: Variable 'DBFileSizeDays' is set to '1'.
6/11 19:59:37.343 360 conf: Variable 'PerformanceMonitorEnabled' is set to 'yes'.
6/11 19:59:37.343 360 conf: Variable 'PerformanceRoot' is set to '.\PerformanceDB'.
6/11 19:59:37.343 360 EventDB: wsRootDir = .\NotifyDB
6/11 19:59:37.406 360 FileBrowser: Directory loaded: *|v|My Computer|*
6/11 19:59:37.406 360 FileBrowser: Directory loaded: *|v|Image Files|img,dat
6/11 19:59:37.406 360 FileBrowser: Directory loaded: *|cdmfv|Event Logs|txt,log
6/11 19:59:37.625 360 Sw: DllMain: Initialize CDDS task descriptor...
6/11 19:59:37.625 360 Sw: DllMain: CDDS task has has been reset: IsTaskScheduled: 0, SPStatus: 0
6/11 19:59:37.625 360 Sw: DllMain: CDDS task descriptor has been initialized!
6/11 19:59:37.625 360 Sw -> Browser_InitDirInfo: >>
6/11 19:59:37.625 360 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|spbitmap'
6/11 19:59:37.625 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'spbitmap'
6/11 19:59:37.625 360 Sw <- Browser_InitDirInfo: return (0x1)
6/11 19:59:37.625 360 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|Metadata|spmetadata'
Dirname: '*'
Rights: 0x1f
Alias: 'Metadata'
Extensions: 'spmetadata'
6/11 19:59:37.625 360 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|Data|spdata'
Dirname: '*'
Rights: 0x1f
Alias: 'Data'
Extensions: 'spdata'
6/11 19:59:37.625 360 Sw: SscPort_Init: (build 20120417, built Apr 17 2012 16:22:37)
VendorId = ' '
ProductId = ' '
Revision = '0001'
6/11 19:59:37.625 360 conf: 'DDDisk.dll' loaded successfully.
6/11 19:59:37.640 360 RAM: SscPort_Init: (build 20120417, built Apr 17 2012 16:22:29)
VendorId = ' '
ProductId = ' '
Revision = '0001'
6/11 19:59:37.640 360 conf: 'RamDisk.dll' loaded successfully.
6/11 19:59:37.718 360 Sw -> Browser_InitDirInfo: >>
6/11 19:59:37.718 360 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|img'
6/11 19:59:37.718 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Extensions: 'img'
6/11 19:59:37.718 360 Sw <- Browser_InitDirInfo: return (0x1)
6/11 19:59:37.718 360 IMG: SscPort_Init: (build 20120417, built Apr 17 2012 16:22:31)
VendorId = ' '
ProductId = ' '
Revision = '0001'
Volumes = 0
6/11 19:59:37.718 360 conf: 'ImageFile.dll' loaded successfully.
6/11 19:59:37.750 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
6/11 19:59:37.750 360 conf: 'VirtualDvd.dll' loaded successfully.
6/11 19:59:37.812 360 IBV: *SscPort_Init: Unused parameter: 'module'
6/11 19:59:37.812 360 IBV: *SscPort_Init: Unused parameter: 'type'
6/11 19:59:37.812 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x1e
Alias: 'Snapshots'
Extensions: 'ibvss'
Dirname: '*'
Rights: 0x8
Alias: 'Database'
Extensions: 'ibvdb'
Dirname: '*'
Rights: 0x9
Alias: 'Image Files'
Extensions: 'img,dat'
6/11 19:59:37.812 360 IBV: SscPort_Init: (build 20120417, built Apr 17 2012 16:22:33)
VendorId = ' '
ProductId = ' '
Revision = '0001'
ImageDir = '*\'
ExeDir = 'C:\Program Files\StarWind Software\StarWind\'
6/11 19:59:37.828 360 conf: 'IBVolume.dll' loaded successfully.
6/11 19:59:37.890 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Alias: 'Mirror Volumes'
Extensions: 'mir'
Dirname: '*'
Rights: 0x1f
6/11 19:59:37.890 360 conf: 'Mirror.dll' loaded successfully.
6/11 19:59:37.953 360 DSKBR: SscPort_Init: (built Apr 17 2012 16:22:33)
VendorId = ' '
ProductId = ' '
Revision = '0001'
6/11 19:59:37.953 360 conf: 'DiskBridge.dll' loaded successfully.
6/11 19:59:38.046 360 VTAPE: SscPort_Init: Parse ImageDir: '*|cmdfv|My Computer|vtl'
6/11 19:59:38.046 360 VTAPE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'vtl'
6/11 19:59:38.046 360 VTAPE: SscPort_Init: Comment : ''
6/11 19:59:38.046 360 VTAPE: *** SscPort_Init: Logging level is set to 1.
6/11 19:59:38.046 360 VTAPE: *** SscPort_Init: DBG_ERROR statements are ON.
6/11 19:59:38.046 360 VTAPE: SscPort_Init: (built Sep 9 2010 11:28:35)
VendorId = ' '
ProductId = ' '
Revision = ' '
DefImageDir = '*\'
Volumes = 0
6/11 19:59:38.046 360 VTAPE: *** TapeEmulCtrlApiStart: StarWind VTL License Type is 3
6/11 19:59:38.046 360 VTAPE: *** TapeEmulCtrlApiStart: This Enterprise Edition supports a maximum of 64 devices, each up to 2097152 MB in length.
6/11 19:59:38.046 360 conf: 'VirtualTape.dll' loaded successfully.
6/11 19:59:38.250 360 HA: *SscPort_InitEx: Unused parameter: 'module'
6/11 19:59:38.265 360 HA: *SscPort_InitEx: Unused parameter: 'type'
6/11 19:59:38.265 360 Sw -> Browser_InitDirInfo: >>
6/11 19:59:38.265 360 Sw: Browser_InitDirInfo: Parse ImageDir: '*|cmdfv|My Computer|img'
6/11 19:59:38.265 360 Sw: *Browser_InitDirInfo:
Dirname: '*'
Rights: 0x1f
Extensions: 'img'
6/11 19:59:38.265 360 Sw <- Browser_InitDirInfo: return (0x1)
6/11 19:59:38.265 360 HA: SscPort_InitEx: OS major version less or equel to 5, then will be used msinitiator transport.6/11 19:59:38.265 360 HA: SscPort_InitEx: (build 20120417, built Apr 17 2012 16:22:31)
VendorId = ' '
ProductId = ' '
Revision = '0001'
DefImageDir = '*\'
Volumes = 0
6/11 19:59:38.265 360 HA: CHADevice::InitializeModule: Params(p_hCxxLogger = 0x004A6750, p_pCallback = 0x0043CD41, p_hPluginHandle = 0x000CFF78, p_ScsiTransportType = 2) ENTERed
6/11 19:59:38.296 360 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: Check is exist old sessions with substring 'iqn.2008-08.com.starwindsoftware:' in initiator name...
6/11 19:59:38.296 360 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: List of persistent login targets is empty.
6/11 19:59:38.296 360 HA: CMSInitiatorISCSITransport::RemoveTargetsByInitatorNameSubset: Old sessions are not found.
6/11 19:59:38.296 360 conf: 'HAImage.dll' loaded successfully.
6/11 19:59:38.312 360 Tgt: : parameter 'file', value 'My Computer\D\Archive.img'.
6/11 19:59:38.312 360 Tgt: : parameter 'asyncmode', value 'yes'.
6/11 19:59:38.312 360 Tgt: : parameter 'CacheMode', value 'none'.
6/11 19:59:38.312 360 IMG: SscPort_Create: Opening device 'ImageFile1', image file 'My Computer\D\Archive.img', buffering=0, async=1, readonly=0.
6/11 19:59:38.328 360 IMG: ImageFile_Create: 'D:\Archive.img': type 0, geometry: sct 16, trks 32, cyl 397312, TotalSectors: 203423744
6/11 19:59:38.328 360 Ssc: *** SscScsi_GetVolumeSectorSize: '\\.\D:' IOCTL_STORAGE_QUERY_PROPERTY(StorageAccessAlignmentProperty) failed (error 87)
6/11 19:59:38.328 360 IMG: ImageFile_Create: VendorId 'ROCKET ', ProductId 'IMAGEFILE ', Revision '0001', Serial '660F1495B76764F7'
6/11 19:59:38.328 360 conf: Device [0x000D9F28] 'ImageFile1' has been created.
6/11 19:59:38.328 360 Tgt: : parameter 'file', value 'My Computer\E\VMs_01.img'.
6/11 19:59:38.328 360 Tgt: : parameter 'asyncmode', value 'yes'.
6/11 19:59:38.328 360 Tgt: : parameter 'CacheMode', value 'none'.
6/11 19:59:38.328 360 IMG: SscPort_Create: Opening device 'ImageFile2', image file 'My Computer\E\VMs_01.img', buffering=0, async=1, readonly=0.
6/11 19:59:38.328 360 IMG: ImageFile_Create: 'E:\VMs_01.img': type 0, geometry: sct 16, trks 32, cyl 1208320, TotalSectors: 618659840
6/11 19:59:38.328 360 Ssc: *** SscScsi_GetVolumeSectorSize: '\\.\E:' IOCTL_STORAGE_QUERY_PROPERTY(StorageAccessAlignmentProperty) failed (error 87)
6/11 19:59:38.328 360 IMG: ImageFile_Create: VendorId 'ROCKET ', ProductId 'IMAGEFILE ', Revision '0001', Serial '5B050487AB030B1F'
6/11 19:59:38.328 360 conf: Device [0x000D1648] 'ImageFile2' has been created.
6/11 19:59:38.328 360 Tgt: : parameter 'file', value 'My Computer\E\VMs_02.img'.
6/11 19:59:38.328 360 IMG: SscPort_Create: Opening device 'ImageFile3', image file 'My Computer\E\VMs_02.img', buffering=0, async=1, readonly=0.
6/11 19:59:38.359 360 IMG: ImageFile_Create: 'E:\VMs_02.img': type 0, geometry: sct 16, trks 32, cyl 1187840, TotalSectors: 608174080
6/11 19:59:38.359 360 Ssc: *** SscScsi_GetVolumeSectorSize: '\\.\E:' IOCTL_STORAGE_QUERY_PROPERTY(StorageAccessAlignmentProperty) failed (error 87)
6/11 19:59:38.359 360 IMG: ImageFile_Create: VendorId 'ROCKET ', ProductId 'IMAGEFILE ', Revision '0001', Serial '94FB8263DEB59AFF'
6/11 19:59:38.359 360 conf: Device [0x000DEA18] 'ImageFile3' has been created.
6/11 19:59:38.359 360 Srv: Creating target 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', device list 'ImageFile1'...
6/11 19:59:38.375 360 Tgt: : parameter 'header', value '0'.
6/11 19:59:38.375 360 Tgt: : parameter 'file', value 'My Computer\D\Archive.img'.
6/11 19:59:38.375 360 Tgt: : parameter 'buffering', value 'no'.
6/11 19:59:38.375 360 Tgt: : parameter 'asyncmode', value 'yes'.
6/11 19:59:38.375 360 Tgt: : parameter 'ImageSizeLow', value '1073741824'.
6/11 19:59:38.375 360 Tgt: : parameter 'ImageSizeHigh', value '24'.
6/11 19:59:38.375 360 Tgt: : parameter 'readonly', value 'no'.
6/11 19:59:38.375 360 Tgt: : parameter 'CacheMode', value 'none'.
6/11 19:59:38.375 360 Tgt: : parameter 'CacheSizeMB', value '0'.
6/11 19:59:38.375 360 Tgt: : parameter 'CacheBlockExpiryPeriodMS', value '0'.
6/11 19:59:38.375 360 Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'.
6/11 19:59:38.375 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: device ImageFile1: new LUN 0 mapped to target LUN 0.
6/11 19:59:38.375 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100: attached device ImageFile1 (found 1 LUNs).
6/11 19:59:38.375 360 conf: Target [0x000DD0C0] 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100' has been created, 1 devices attached.
6/11 19:59:38.375 360 Srv: Creating target 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', device list 'ImageFile2'...
6/11 19:59:38.406 360 Tgt: : parameter 'header', value '0'.
6/11 19:59:38.406 360 Tgt: : parameter 'file', value 'My Computer\E\VMs_01.img'.
6/11 19:59:38.406 360 Tgt: : parameter 'buffering', value 'no'.
6/11 19:59:38.406 360 Tgt: : parameter 'asyncmode', value 'yes'.
6/11 19:59:38.406 360 Tgt: : parameter 'ImageSizeLow', value '3221225472'.
6/11 19:59:38.406 360 Tgt: : parameter 'ImageSizeHigh', value '73'.
6/11 19:59:38.406 360 Tgt: : parameter 'readonly', value 'no'.
6/11 19:59:38.406 360 Tgt: : parameter 'CacheMode', value 'none'.
6/11 19:59:38.406 360 Tgt: : parameter 'CacheSizeMB', value '0'.
6/11 19:59:38.406 360 Tgt: : parameter 'CacheBlockExpiryPeriodMS', value '0'.
6/11 19:59:38.406 360 Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'.
6/11 19:59:38.406 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: device ImageFile2: new LUN 0 mapped to target LUN 0.
6/11 19:59:38.406 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201: attached device ImageFile2 (found 1 LUNs).
6/11 19:59:38.406 360 conf: Target [0x000DF848] 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201' has been created, 1 devices attached.
6/11 19:59:38.406 360 Srv: Creating target 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', device list 'ImageFile3'...
6/11 19:59:38.421 360 Tgt: : parameter 'header', value '0'.
6/11 19:59:38.421 360 Tgt: : parameter 'file', value 'My Computer\E\VMs_02.img'.
6/11 19:59:38.421 360 Tgt: : parameter 'buffering', value 'no'.
6/11 19:59:38.421 360 Tgt: : parameter 'asyncmode', value 'yes'.
6/11 19:59:38.421 360 Tgt: : parameter 'ImageSizeLow', value '2147483648'.
6/11 19:59:38.421 360 Tgt: : parameter 'ImageSizeHigh', value '72'.
6/11 19:59:38.421 360 Tgt: : parameter 'readonly', value 'no'.
6/11 19:59:38.421 360 Tgt: : parameter 'CacheMode', value 'none'.
6/11 19:59:38.421 360 Tgt: : parameter 'CacheSizeMB', value '0'.
6/11 19:59:38.421 360 Tgt: : parameter 'CacheBlockExpiryPeriodMS', value '0'.
6/11 19:59:38.421 360 Tgt: : parameter '#_TargetName_#', value 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'.
6/11 19:59:38.421 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: device ImageFile3: new LUN 0 mapped to target LUN 0.
6/11 19:59:38.421 360 Tgt: iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202: attached device ImageFile3 (found 1 LUNs).
6/11 19:59:38.421 360 conf: Target [0x000E1008] 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202' has been created, 1 devices attached.
6/11 19:59:38.421 360 conf: Reaction of type 'eventlog' [0x0000003E, 0x0C] loaded successfully.
6/11 19:59:38.421 360 conf: Variable 'DefaultAccessPolicy' is set to 'allow'.
6/11 19:59:38.421 360 Srv: Update tracker options: UpdatePeriod = 7, UpdateLastRequest = 20120604, UpdateHost = www.starwindsoftware.com, UpdatePage = /updatetracker/index.php, UpdatePort = 80, UpdateCopyId = EA935F61-1974-4CF8-A4ABEADF3A56C1F2
6/11 19:59:38.421 360 Srv: Refreshing device list (complete)...
6/11 19:59:38.437 360 SPTI: '\\?\scsi#disk&ven_dell&prod_array&rev_v1.0#5&1f7d4b27&0&400#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'DELL Array V1.0': adapter 2, bus 4, target 0, LUN 0; maxTransferLength 65536, alignmentMask 0x0
6/11 19:59:38.437 360 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 00000000, Record: 00000000).
6/11 19:59:38.437 360 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
6/11 19:59:38.437 360 SPTI: '\\?\scsi#disk&ven_dell&prod_array&rev_v1.0#5&1f7d4b27&0&410#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'DELL Array V1.0': adapter 2, bus 4, target 1, LUN 0; maxTransferLength 65536, alignmentMask 0x0
6/11 19:59:38.453 360 Srv: Waiting for iSCSI connections at 0.0.0.0:3260 ...
6/11 19:59:38.453 3a4 conf: Waiting for Control connections at 0.0.0.0:3261 ...
6/11 19:59:38.453 3a8 bc: Waiting for broadcast UDP packets at 0.0.0.0:3261...
6/11 19:59:38.453 360 Srv: Waiting for iSCSI connections at 192.168.100.60:3260 ...
6/11 19:59:38.468 360 Srv: Waiting for iSCSI connections at 127.0.0.1:3260 ...
6/11 20:03:18.187 360 Srv: Accepted iSCSI connection from 192.168.100.20:56217 to 192.168.100.60:3260. (Id = 0x1)
6/11 20:03:18.203 360 C[1], FREE: Event - CONNECTED.
6/11 20:03:18.203 360 C[1], XPT_UP: T3.
6/11 20:03:18.203 fc8 C[1], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 20:03:18.203 fc8 C[1], XPT_UP: Event - LOGIN.
6/11 20:03:18.203 fc8 C[1], IN_LOGIN: T4.
6/11 20:03:18.203 fc8 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:18.203 fc8 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 20:03:18.203 fc8 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:18.203 fc8 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:18.203 fc8 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 20:03:18.203 fc8 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:18.203 fc8 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:18.203 fc8 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:18.203 fc8 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:18.203 fc8 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 20:03:18.203 fc8 Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:18.203 fc8 Params: >>> HeaderDigest=None.
6/11 20:03:18.203 fc8 Params: >>> DataDigest=None.
6/11 20:03:18.203 fc8 Params: >>> OFMarker=No.
6/11 20:03:18.203 fc8 Params: >>> IFMarker=No.
6/11 20:03:18.203 fc8 Params: >>> InitialR2T=No.
6/11 20:03:18.218 fc8 Params: >>> ImmediateData=Yes.
6/11 20:03:18.218 fc8 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:18.218 fc8 Params: >>> MaxBurstLength=262144.
6/11 20:03:18.218 fc8 Params: >>> FirstBurstLength=262144.
6/11 20:03:18.218 fc8 Params: >>> DefaultTime2Wait=0.
6/11 20:03:18.218 fc8 Params: >>> DefaultTime2Retain=0.
6/11 20:03:18.218 fc8 Params: >>> MaxOutstandingR2T=1.
6/11 20:03:18.218 fc8 Params: >>> DataPDUInOrder=Yes.
6/11 20:03:18.218 fc8 Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:18.218 fcc T[1,1]: session 0x1, connection 0x1 : end of stage 1, next stage 3.
6/11 20:03:18.218 fcc C[1], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:18.218 fcc C[1], LIN: T5.
6/11 20:03:18.218 fcc C[1], LIN: Event - LOGOUT.
6/11 20:03:18.218 fcc C[1], IN_LOGOUT: T9/10.
6/11 20:03:18.218 fc4 C[1], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 20:03:18.218 fc4 C[1], FREE: T13.
6/11 20:03:18.218 fc8 C[1], FREE: recvData returned 10054
6/11 20:03:18.234 360 Srv: Accepted iSCSI connection from 192.168.100.20:53440 to 192.168.100.60:3260. (Id = 0x2)
6/11 20:03:18.234 360 C[2], FREE: Event - CONNECTED.
6/11 20:03:18.234 360 C[2], XPT_UP: T3.
6/11 20:03:18.250 360 Srv: Accepted iSCSI connection from 192.168.100.20:59347 to 192.168.100.60:3260. (Id = 0x3)
6/11 20:03:18.250 360 C[3], FREE: Event - CONNECTED.
6/11 20:03:18.250 360 C[3], XPT_UP: T3.
6/11 20:03:18.250 360 Srv: Accepted iSCSI connection from 192.168.100.20:49801 to 192.168.100.60:3260. (Id = 0x4)
6/11 20:03:18.250 360 C[4], FREE: Event - CONNECTED.
6/11 20:03:18.250 360 C[4], XPT_UP: T3.
6/11 20:03:18.515 fd4 C[2], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 20:03:18.515 fe0 C[3], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 20:03:18.515 fd4 C[2], XPT_UP: Event - LOGIN.
6/11 20:03:18.515 fd4 C[2], IN_LOGIN: T4.
6/11 20:03:18.515 fd4 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:18.515 fd4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100'
6/11 20:03:18.515 fd4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 20:03:18.515 fd4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fd4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fe0 C[3], XPT_UP: Event - LOGIN.
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 20:03:18.515 fe0 C[3], IN_LOGIN: T4.
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 20:03:18.515 fe0 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 20:03:18.515 fe0 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201'
6/11 20:03:18.515 fd4 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 20:03:18.515 fd4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 20:03:18.515 fe0 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fe0 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 20:03:18.515 fe0 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 20:03:18.515 fec C[4], XPT_UP: Login request: ISID 0x00023d000001, TSIH 0x0000.
6/11 20:03:18.515 fec C[4], XPT_UP: Event - LOGIN.
6/11 20:03:18.515 fec C[4], IN_LOGIN: T4.
6/11 20:03:18.515 fec Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:18.515 fec Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202', accepted 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202'
6/11 20:03:18.515 fec Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/11 20:03:18.515 fec Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fec Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:18.515 fec Params: <<< Numeric param 'DefaultTime2Wait': received 2, accepted 2
6/11 20:03:18.515 fec Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:18.515 fec Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:18.515 fec Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:18.515 fec Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:18.515 fec Params: <<< Boolean param 'InitialR2T': received No, accepted 0
6/11 20:03:18.515 fec Params: <<< Boolean param 'ImmediateData': received Yes, accepted 1
6/11 20:03:18.515 fec Params: <<< Numeric param 'MaxBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fec Params: <<< Numeric param 'FirstBurstLength': received 262144, accepted 262144
6/11 20:03:18.515 fec Params: <<< Numeric param 'MaxOutstandingR2T': received 1, accepted 1
6/11 20:03:18.515 fec Params: <<< Numeric param 'MaxConnections': received 1, accepted 1
6/11 20:03:18.515 fec Params: <<< Boolean param 'DataPDUInOrder': received Yes, accepted 1
6/11 20:03:18.515 fec Params: <<< Boolean param 'DataSequenceInOrder': received Yes, accepted 1
6/11 20:03:18.515 fec Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 131072, accepted 131072
6/11 20:03:18.515 fec Tgt: open 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun202': 1 session(s) opened, 0 more allowed.
6/11 20:03:18.515 fe0 Tgt: open 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun201': 1 session(s) opened, 0 more allowed.
6/11 20:03:18.515 fd4 Tgt: open 'iqn.2008-08.com.starwindsoftware:192.168.100.60-lun100': 1 session(s) opened, 0 more allowed.
6/11 20:03:18.515 fe0 Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:18.515 fd4 Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:18.515 fe0 Params: >>> MaxConnections=1.
6/11 20:03:18.515 fd4 Params: >>> MaxConnections=1.
6/11 20:03:18.515 fe0 Params: >>> HeaderDigest=None.
6/11 20:03:18.515 fd4 Params: >>> HeaderDigest=None.
6/11 20:03:18.515 fe0 Params: >>> DataDigest=None.
6/11 20:03:18.515 fd4 Params: >>> DataDigest=None.
6/11 20:03:18.515 fe0 Params: >>> TargetAlias=LUN201.
6/11 20:03:18.515 fd4 Params: >>> TargetAlias=LUN100.
6/11 20:03:18.515 fe0 Params: >>> OFMarker=No.
6/11 20:03:18.515 fd4 Params: >>> OFMarker=No.
6/11 20:03:18.515 fe0 Params: >>> IFMarker=No.
6/11 20:03:18.515 fd4 Params: >>> IFMarker=No.
6/11 20:03:18.515 fe0 Params: >>> InitialR2T=No.
6/11 20:03:18.515 fd4 Params: >>> InitialR2T=No.
6/11 20:03:18.515 fe0 Params: >>> ImmediateData=Yes.
6/11 20:03:18.515 fd4 Params: >>> ImmediateData=Yes.
6/11 20:03:18.515 fe0 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:18.515 fd4 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:18.515 fe0 Params: >>> MaxBurstLength=262144.
6/11 20:03:18.515 fd4 Params: >>> MaxBurstLength=262144.
6/11 20:03:18.515 fe0 Params: >>> FirstBurstLength=262144.
6/11 20:03:18.515 fd4 Params: >>> FirstBurstLength=262144.
6/11 20:03:18.515 fe0 Params: >>> DefaultTime2Wait=2.
6/11 20:03:18.515 fd4 Params: >>> DefaultTime2Wait=2.
6/11 20:03:18.515 fe0 Params: >>> DefaultTime2Retain=0.
6/11 20:03:18.515 fd4 Params: >>> DefaultTime2Retain=0.
6/11 20:03:18.515 fe0 Params: >>> MaxOutstandingR2T=1.
6/11 20:03:18.515 fd4 Params: >>> MaxOutstandingR2T=1.
6/11 20:03:18.515 fe0 Params: >>> DataPDUInOrder=Yes.
6/11 20:03:18.515 fd4 Params: >>> DataPDUInOrder=Yes.
6/11 20:03:18.515 fe0 Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:18.515 fd4 Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:18.515 fe0 Params: >>> TargetPortalGroupTag=1.
6/11 20:03:18.515 fd4 Params: >>> TargetPortalGroupTag=1.
6/11 20:03:18.515 fec Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:18.515 fec Params: >>> MaxConnections=1.
6/11 20:03:18.515 fec Params: >>> HeaderDigest=None.
6/11 20:03:18.515 fec Params: >>> DataDigest=None.
6/11 20:03:18.515 fec Params: >>> TargetAlias=LUN202.
6/11 20:03:18.515 fec Params: >>> OFMarker=No.
6/11 20:03:18.515 fec Params: >>> IFMarker=No.
6/11 20:03:18.515 fec Params: >>> InitialR2T=No.
6/11 20:03:18.515 fec Params: >>> ImmediateData=Yes.
6/11 20:03:18.515 fd8 T[2,1]: session 0x2, connection 0x2 : end of stage 1, next stage 3.
6/11 20:03:18.515 fec Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:18.515 fd8 C[2], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:18.515 fec Params: >>> MaxBurstLength=262144.
6/11 20:03:18.515 fd8 C[2], LIN: T5.
6/11 20:03:18.515 fec Params: >>> FirstBurstLength=262144.
6/11 20:03:18.515 fec Params: >>> DefaultTime2Wait=2.
6/11 20:03:18.515 fec Params: >>> DefaultTime2Retain=0.
6/11 20:03:18.515 fec Params: >>> MaxOutstandingR2T=1.
6/11 20:03:18.515 fec Params: >>> DataPDUInOrder=Yes.
6/11 20:03:18.515 fec Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:18.515 fec Params: >>> TargetPortalGroupTag=1.
6/11 20:03:18.515 fe4 T[3,1]: session 0x3, connection 0x3 : end of stage 1, next stage 3.
6/11 20:03:18.515 ff0 T[4,1]: session 0x4, connection 0x4 : end of stage 1, next stage 3.
6/11 20:03:18.515 fe4 C[3], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:18.515 ff0 C[4], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:18.515 fe4 C[3], LIN: T5.
6/11 20:03:18.515 ff0 C[4], LIN: T5.
6/11 20:03:19.265 360 Srv: Accepted iSCSI connection from 192.168.100.20:62929 to 192.168.100.60:3260. (Id = 0x5)
6/11 20:03:19.265 360 C[5], FREE: Event - CONNECTED.
6/11 20:03:19.265 360 C[5], XPT_UP: T3.
6/11 20:03:19.265 ff8 C[5], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 20:03:19.265 ff8 C[5], XPT_UP: Event - LOGIN.
6/11 20:03:19.265 ff8 C[5], IN_LOGIN: T4.
6/11 20:03:19.265 ff8 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:19.265 ff8 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 20:03:19.265 ff8 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:19.265 ff8 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:19.265 ff8 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 20:03:19.265 ff8 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:19.265 ff8 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:19.265 ff8 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:19.265 ff8 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:19.265 ff8 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 20:03:19.265 ff8 Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:19.265 ff8 Params: >>> HeaderDigest=None.
6/11 20:03:19.265 ff8 Params: >>> DataDigest=None.
6/11 20:03:19.265 ff8 Params: >>> OFMarker=No.
6/11 20:03:19.265 ff8 Params: >>> IFMarker=No.
6/11 20:03:19.265 ff8 Params: >>> InitialR2T=No.
6/11 20:03:19.265 ff8 Params: >>> ImmediateData=Yes.
6/11 20:03:19.265 ff8 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:19.265 ff8 Params: >>> MaxBurstLength=262144.
6/11 20:03:19.265 ff8 Params: >>> FirstBurstLength=262144.
6/11 20:03:19.265 ff8 Params: >>> DefaultTime2Wait=0.
6/11 20:03:19.265 ff8 Params: >>> DefaultTime2Retain=0.
6/11 20:03:19.265 ff8 Params: >>> MaxOutstandingR2T=1.
6/11 20:03:19.265 ff8 Params: >>> DataPDUInOrder=Yes.
6/11 20:03:19.265 ff8 Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:19.265 ffc T[5,1]: session 0x5, connection 0x5 : end of stage 1, next stage 3.
6/11 20:03:19.265 ffc C[5], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:19.265 ffc C[5], LIN: T5.
6/11 20:03:19.281 ffc C[5], LIN: Event - LOGOUT.
6/11 20:03:19.281 ffc C[5], IN_LOGOUT: T9/10.
6/11 20:03:19.281 ff4 C[5], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 20:03:19.281 ff4 C[5], FREE: T13.
6/11 20:03:19.281 ff8 C[5], FREE: recvData returned 10054
6/11 20:03:30.109 360 Srv: Accepted iSCSI connection from 192.168.100.20:52754 to 192.168.100.60:3260. (Id = 0x6)
6/11 20:03:30.109 360 C[6], FREE: Event - CONNECTED.
6/11 20:03:30.109 360 C[6], XPT_UP: T3.
6/11 20:03:30.109 98 C[6], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
6/11 20:03:30.109 98 C[6], XPT_UP: Event - LOGIN.
6/11 20:03:30.109 98 C[6], IN_LOGIN: T4.
6/11 20:03:30.109 98 Params: <<< String param 'InitiatorName': received 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc', accepted 'iqn.1998-01.com.vmware:vshost-01-2b2aacdc'
6/11 20:03:30.109 98 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
6/11 20:03:30.109 98 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
6/11 20:03:30.109 98 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
6/11 20:03:30.109 98 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
6/11 20:03:30.109 98 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
6/11 20:03:30.109 98 Params: <<< Boolean param 'IFMarker': received No, accepted 0
6/11 20:03:30.109 98 Params: <<< Boolean param 'OFMarker': received No, accepted 0
6/11 20:03:30.109 98 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
6/11 20:03:30.109 98 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
6/11 20:03:30.109 98 Params: >>> ErrorRecoveryLevel=0.
6/11 20:03:30.109 98 Params: >>> HeaderDigest=None.
6/11 20:03:30.109 98 Params: >>> DataDigest=None.
6/11 20:03:30.109 98 Params: >>> OFMarker=No.
6/11 20:03:30.109 98 Params: >>> IFMarker=No.
6/11 20:03:30.109 98 Params: >>> InitialR2T=No.
6/11 20:03:30.109 98 Params: >>> ImmediateData=Yes.
6/11 20:03:30.109 98 Params: >>> MaxRecvDataSegmentLength=262144.
6/11 20:03:30.109 98 Params: >>> MaxBurstLength=262144.
6/11 20:03:30.109 98 Params: >>> FirstBurstLength=262144.
6/11 20:03:30.109 98 Params: >>> DefaultTime2Wait=0.
6/11 20:03:30.109 98 Params: >>> DefaultTime2Retain=0.
6/11 20:03:30.109 98 Params: >>> MaxOutstandingR2T=1.
6/11 20:03:30.109 98 Params: >>> DataPDUInOrder=Yes.
6/11 20:03:30.109 98 Params: >>> DataSequenceInOrder=Yes.
6/11 20:03:30.109 d0 T[6,1]: session 0x6, connection 0x6 : end of stage 1, next stage 3.
6/11 20:03:30.109 d0 C[6], IN_LOGIN: Event - LOGIN_ACCEPT.
6/11 20:03:30.109 d0 C[6], LIN: T5.
6/11 20:03:30.125 d0 C[6], LIN: Event - LOGOUT.
6/11 20:03:30.125 d0 C[6], IN_LOGOUT: T9/10.
6/11 20:03:30.125 94 C[6], IN_LOGOUT: Event - LOGOUT_ACCEPT.
6/11 20:03:30.125 94 C[6], FREE: T13.
6/11 20:03:30.125 98 C[6], FREE: recvData returned 10054
Tue Jun 12, 2012 1:48 pm
It seems like you haven`t checked in Clustering checkbox while coomplishing target wizard. You need to re-create the target to enable it now.
Awx
Tue Jun 12, 2012 3:40 pm
Hi Anatoly
I knew there was something I'd missed !!
Many thanks - I'll recreate and try again.
The software rocks by the way :)
Andy
Wed Jun 13, 2012 11:24 am
Thanks for the feedback! We are here working hard to rock hard 8)
Please keep us updated!
Awx
Wed Jun 13, 2012 12:57 pm
Thanks !!
Worked a treat !
Andy
Wed Jun 13, 2012 2:12 pm
Good. Please keep us updated about your progress. Thanks!
