Cannot create VTL device using trial License
zeero
Mon Sep 12, 2011 7:47 pm
Hello all
I downloaded Startwind 5.7 trial and tried to create a virtual tape library using my trial license, but every time i go on the wizard to create the device the software tells me that it is not licensed feature.
so what is the process to check this feature?
thanks in advance
Tue Sep 13, 2011 7:59 am
It is possible that you have downloaded Free license key instead of trial. Could you please doublecheck this? I will check now in which key it is included in.
raymondjt
Wed Oct 05, 2011 5:28 pm
Hi, I have the same problem. With the trial key NO VTL is enabled to try.
Raymond
Thu Oct 06, 2011 8:03 am
Well yes, it is not included into the usual trial license. If you would like to test VTL please contact our sales by using the email below and they will provide you with all required information and keys:
sales@starwindsoftware.com
