StarWind iSCSI SAN
(Resolved)HyperV Shared VHDX anyone using it with starwind ?
Postby RaymondTH » Thu Apr 10, 2014 4:27 pm
edit Ok I figured out how to fix this issue, After searching the code online I found a post about someone trying to use this feature and getting the same error code with the vhds on the iscsi disks of a consumer nas which didn't support kerberos authentication.
Even though I had the cluster setup so the iscsi sync network was set to "do not allow cluster communication" and not used for live migration it was still trying to use this network for the shared vhdx.
The cause was the network binding order which had the iscsi nic above the server one. After putting the 10.0.0.x server adapter on top and rebooting no more messages appeared in the shared vhdx event log section and failover of the guest clusters worked.
Hope this helps anyone else who has this problem.
Hi ive been having an issue with my hyperv cluster on 2012 r2 with the latest starwind 8 RC and the new shared VHDX feature of server 2012 (This allows us to create guest clusters without installing mpio and setting up icsi on the guest nodes) I can create the cluster successfully but if any node is live migrated or the hyperv server restarts the failover doesn't work. The event log shows
Error attaching to volume. Volume: \Device\HarddiskVolumeShadowCopy4. Error: The specified request is not a valid operation for the target device..
Error opening handle for initiator. Initiator: {914c57ed-53a7-48fc-b5a8-edce7a25456b}. Hostname: HYPERV1. File: \SCFS QUORUM.VHDX:SHAREDVIRTUALDISK. Error: The request is not supported..
IP is as follows
HyperV 10.0.0.1,10.0.0.5,10.0.5.1,169.254.2.81 Online-
HYPERV1 10.0.0.1,10.0.0.5,10.0.5.1,169.254.2.81 Online
HYPERV2 10.0.0.2,10.0.5.2,169.254.1.91 Online
10.0.0.1 = HyperV1 Server IP (Teamed NC380T)
10.0.5.1 = (Teamed IPoIP)
Ethernet adapter Infiniband:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Network Adapter Multiplexor Driver #2
Physical Address. . . . . . . . . : 00-1A-4B-0C-02-21
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 10.0.5.1(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter vEthernet (ServerNet):
Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
Physical Address. . . . . . . . . : 00-1C-C4-DF-92-FE
IPv4 Address. . . . . . . . . . . : 10.0.0.1(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.5(Preferred)
Default Gateway . . . . . . . . . : 10.0.0.20
DNS Servers . . . . . . . . . . . : 10.0.0.11
10.0.0.12
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Failover Cluster Virtual Adapter
Physical Address. . . . . . . . . : 02-BA-71-68-E8-DA
IPv4 Address. . . . . . . . . . . : 169.254.2.81(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
and .2 for Hyperv2. I have also
Has anyone successfully got this feature to work on their starwind cluster ? Im not sure if its a starwind issue or a windows one.
RaymondTH
Re: (Resolved)HyperV Shared VHDX anyone using it with starwind ?
Postby Bohdan (staff) » Mon Apr 14, 2014 8:38 am
Thank you for sharing this information!
Bohdan (staff)
Return to Public Beta
Who is online
