Moving the data store location
JonOrt
Fri Jan 24, 2014 8:26 pm
I can't seem to move the file location for a virtual disk. If I create a device with physical storage at say C:\Storage it works fine. Then I remove the device without deleting the storage, and copy the files to C:\Storage_new. If I then go to create new device (advanced) and tell it to use an existing virtual drive at C:\Storage_new the function completes but the device is listed as in-active and there seems to be nothing I can do to make it work. I did this pretty regularly with V.6 and had no issues.
Any thoughts (Console 8.0.6312 / 8.0 Plug-ins)?
Bohdan (staff)
Mon Feb 03, 2014 10:25 am
Storage movement in StarWind will be implemented soon.
In case of manual movement please edit the swdsk file and specify the new virtual disk (img or spsp file) location under "storage" section.
