StarWind iSCSI SAN
Thick provisioned virtual disks
Postby turkina » Mon Oct 14, 2013 5:51 pm
Am I just dumb? I have a 705GB vDisk created on my Windows 2012 server out of my Storage Spaces Storage Pool. I attempt to create a device in Starwind v8 Beta and point it at P: (where the vDisk is mounted) and try to create a 700GB thick provisioned virtual disk.
"Not enough disk space."
OK, how about 699GB? No. 690GB? No. 600GB? No. 100GB? That works. WTF?
Is thick provisioned virtual disks broken?
turkina
Re: Thick provisioned virtual disks
Postby Bohdan (staff) » Mon Oct 14, 2013 7:56 pm
I assume the P: volume is a newly created and blank one and it definitely has enough free space. :D
OK, let me check that in our testlab.
Bohdan (staff)
Postby turkina » Mon Oct 14, 2013 8:39 pm
Figured it out.
Even though I was telling the new virtual disk to go to P:\, Starwind had a default Storage Pool entry of C:\Storage and was attempting to put the new device there rather than P:\.
After I changed the default Storage Pool location to P:\ then I could create the thick provisioned virtual disk and create a device. Looks like I'll have to change that default every time I provision a virtual disk if I want it in a different location.
turkina
Postby Anatoly (staff) » Wed Oct 16, 2013 11:26 am
Well, the obvious reasons are the most hard to find :)
Anyway, we are glad that you are all set now,
[email protected]
Postby turkina » Wed Oct 16, 2013 4:57 pm
Is that normal that I should have to change the default storage pool every time I create a device? I'd think setting a custom path at device creation would override the default.
turkina
Postby anton (staff) » Wed Oct 16, 2013 7:09 pm
No it's not. We'll file a bug.
turkina wrote:Is that normal that I should have to change the default storage pool every time I create a device? I'd think setting a custom path at device creation would override the default.
Postby anton (staff) » Thu Oct 17, 2013 10:20 am
Update. Bug is fixed. Beta-2 will be free from it. Stay tuned!
Return to Beta
Who is online
Users browsing this forum: No registered users and 3 guests
