StarWind LUNs is not visible in SCVMM 2012
omar.alshalah
Mon Apr 01, 2013 7:35 am
I have a question regarding creating LUNs, when it is created through StarWind software, it won't show in the SCVMM after adding the provider & the pools..
If I create the LUNs from SCVMM after adding the StarWind Storage provider its showing & working normally (but it will be created without a Target) ...
is this normal behavior or not ??? The SCVMM will not discover the created LUNs in starwind ??
I searched everywhere but I didn't find answer for this question & I followed the pdf guide for installing & configuring SMI-S agent.
I'm using (StarWind-SMIS-20130301.ZIP)
Thank you
Omar
Bohdan (staff)
Tue Apr 02, 2013 1:35 pm
It is right.
The target will be created when you assign the LUN to Hyper-V host in SCVMM console.
omar.alshalah
Thu Apr 04, 2013 4:17 am
Thank you very much ...
Now it's clear :D
Thu Apr 04, 2013 10:13 am
Great to know! :) Let us know should you have further questions.
Fri Sep 06, 2013 8:55 pm
Upgrade to R2 SCVMM Preview and StarWind V8 Beta. You be good! (c) ...
