VHDX file created by StarWind V2V Converter won't boot
e9zlfhZI
Fri Dec 26, 2025 11:31 pm
I tried to create a Hyper-V VM using Disk2VHD. I tried it a couple of times and couldn't get the VM's to start:
Microsoft Hyper-V UEFI
Virtual Machine Boot Summary
1. Network Adapter (00155D018000)
A boot image was not found.
2. SCSI Disk (0,0)
The boot loader did not load an operating system.
No operating system was loaded. Your virtual machine may be configured incorrectly. Exit and re-configure your VM or click restart to retry the current boot sequence again.
I did some research and thought it was because I was I was trying to do it from Disk2VHD on my computer. I couldn't figure out how to get a USB to boot with Windows 11 installed and then start Disk2VHD. So I looked for other solutions ... and found StarWind V2V Converter. I tried that and created a VHDX file.
When I created a VM using that VHDX, it ran ... but the VM never boots!
https://i.imgur.com/TsjGlTT.png
I'm thinking that I didn't create the VHDX file correctly.
There are the 3 disks on the computer:
https://i.imgur.com/ccQU9Mm.png
When I created the VHDX file, these are the options I chose:
Select the location of the image to convert: P2V - Convert physical machine or disk
Select physical data to convert: Physical Disk - Convert the physical disk to a virtual disk file.
Volume structure is preserved. It is possible to select a set of disk volumes for copying to a virtual disk file
In "Select physical disk to convert", there were 5 choices! In my first attempt (no notes on that one) I tried just C:\. This time, I tried all 5: https://i.imgur.com/6cLHNEQ.png
Select the location of the destination image: Local file: File on the local machine
Select destination image format: VHD/VHDX - Microsoft Virtual Hard Disk
Select option for VHD/VHDX image format: VHDX growable image - Disk space for this image is allocated on demand, so disk size of this image grows over time (I did not select "Activate Windows Repair Mode")
https://i.imgur.com/RawSCwl.png
Conversion Log:
Time | Information
14:37:05 | Started
14:37:05 | Opening image file 1
14:37:05 | Taking snapshots...
14:37:40 | Taking snapshot of volume C:\ - success
14:37:40 | Taking snapshot of volume \\?\Volume{61b9c6a7-e911-43da-8ce4-5b2b73d...
14:37:40 | Taking snapshot of volume \\?\Volume{521cae76-7997-4264-bdb5-11be78...
14:37:40 | Taking snapshot of volume \\?\Volume...
14:37:40 | Success
14:37:40 | Creating image file
14:37:40 | Success
14:37:40 | New file Hard Disks\EBT2250-20251226-StarWind V2V.vhdx
14:37:40 | Converting...
16:44:10 | Success
16:44:10 | Converted successfully!
Created VM
Settings > Hardware: https://i.imgur.com/4NoIInd.png
Settings > Management: https://i.imgur.com/Uc1LLYR.png
https://i.imgur.com/WWJwU04.png
Boot failure. Reboot and Select proper Boot device or Insert Boot Media in selected Boot device
Any ideas on what I am doing wrong?
John
Sat Dec 27, 2025 6:44 am
If converted successfully, VM not booting is not the V2V Converter issue.
What V2V does is remap the contents of one file into another (similar to disk2VHD). It does not add or change anything. This being said, the VM is not OK with the destination.
In boot options, please try a different boot order. The VM is now booting from the virtual CD.
e9zlfhZI
Sun Dec 28, 2025 2:46 pm
Thanks @yaroslav, you were correct, it was booting from the CD.
I set it to boot from IDE ... and received the same "Boot failure" message.
Any other ideas?
Thanks very much,
John
brandiknight
Tue Jan 13, 2026 7:44 am
How can I fix a non-bootable VHDX created with StarWind V2V Converter?
Tue Jan 13, 2026 8:10 am
See the lins above.
emelialucass
Wed Jun 24, 2026 12:20 pm
Thanks.
