oVirt --> VMware
penrodcc
Wed Nov 12, 2025 4:14 pm
Hello!
Trying to use the V2V tool and have an issue.
To: VMWare 6.5 (VCenter is 6.7)
Can log into both oVirt and VMWare no issues. It gets stuck at opening image file. I only see these two below errors.
11/12 11:08:14.652 c0c Facility ???ERROR: WrapperKVM::KVMWrapper::KVMWrapperImpl::AddImageTransfer: Error sending request: * Line 1, Column 2 Syntax error: Malformed token
11/12 11:08:34.668 c0c Facility ???ERROR: WrapperKVM::KVMWrapper::KVMWrapperImpl::AddImageTransfer: Error sending request: 400
Thoughts? Thanks in advance!
Wed Nov 12, 2025 6:12 pm
Share the full log please.
penrodcc
Wed Nov 12, 2025 8:16 pm
Please see attached for the full log.
V2V_Log-20251112-120353.tar
(170.5 KiB) Downloaded 727 times
Thu Nov 13, 2025 8:21 am
Thanks for your update.
Is it possible to convert that VM to OVF for now and import it into ESXi?
penrodcc
Thu Nov 13, 2025 1:00 pm
I have ten VM's that I'm hoping to use this tool to migrate. All from ovirt to esx.
I'll try the OVF conversion and see the timing.
Thu Nov 13, 2025 1:03 pm
Is P2V conversion possible, or is converting individual disks for those VMs?
penrodcc
Thu Nov 13, 2025 2:57 pm
These are Linux machines. Looks like your V2V is limited to Windows for p2v?
Thu Nov 13, 2025 3:05 pm
HI,
Yes, that's right.
oVirt <-> ESXi conversions are tested during the QA cycle, so it looks like something funny is happening to this specific system. Please see if the older release works https://drive.google.com/file/d/1hDP4gl ... Ea_5p/view.
penrodcc
Thu Nov 13, 2025 3:27 pm
HI,
Yes, that's right.
Thanks for your help on this!
The version you provided does not have oVirt as an option.
Thu Nov 13, 2025 3:35 pm
Try converting them to qcow2 and create the VM in place.
