V2V ESXI VM to Azure
tahir07860
Tue Oct 21, 2025 8:15 am
I originally got an error about the size of the VM when v2v failed to create the VM. I selected ds4v2 as that supported network acceleration. However a rerun yesterday gave the following error, any help?
10/21 0:37:27.622 2858 Facility ???INFO: CPPConverting::ConvertImage: Success
10/21 0:37:51.096 2858 Facility ???ERROR: VMConverter::AzureConverter::CreateVM: NetworkInterface is empty
10/21 0:37:51.096 2858 Facility ???ERROR: CPPConverting::ConverterAzure: Create VM - Error sending request to Azure.
Network Interface not found.
10/21 0:37:51.549 2858 Facility ???ERROR: WrapperESXI::removeSnapshot: RemoveSnapshot_USCORETask fail - 12
10/21 0:37:51.549 2858 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
10/21 0:37:51.549 2858 Facility ???ERROR: VMConverter::ESXIConverter::DeleteSnapshot: removeSnapshot fail - 12
10/21 0:37:51.549 2858 Facility ???WARNING: CPPConverting::DeleteSnapshot: Error deleting snapshot - The session is not authenticated.
10/21 0:37:51.549 2858 Facility ???ERROR: CPPConverting::Convert: FAILED
Any idea?
Tue Oct 21, 2025 8:46 am
According to the logs, the issue is on the Azure side. Authentication does not work OK.
Make sure that your Azure application is configured right. Check this bit https://www.starwindsoftware.com/v2v-he ... Azure.html
TrentonCollier
Tue Dec 02, 2025 2:48 am
Make sure that your Azure application is configured right. Check this bit https://www.starwindsoftware.com/v2v-he ... Azure.html x trench run
I have successfully solved that problem, thank you.
Last edited by TrentonCollier on Sat Dec 13, 2025 1:22 am, edited 1 time in total.
Tue Dec 02, 2025 4:25 am
Thanks for your update!
