P2V to Hyper-V 2022 stuck at connecting please wait
certinet
Fri Jul 25, 2025 12:41 pm
Trying to configure a computer on a domain to Hyper-V 2022 Core. At entering the parameters for Hyper-V, it get stuck at Connecting. Please wait. Firewall is off on the Hyper-V Server. Logs shows:
7/24 18:07:23.808 3b998 Facility ???INFO: WrapperHyperV::connect: Host - \\MACHINENAME\root\virtualization\v2
7/24 18:37:23.906 3b998 Facility ???ERROR: WrapperHyperV::connect: pLoc->ConnectServer \\MACHINENAME\root\virtualization\v2 - 0x800706bf
7/24 18:37:23.906 3b998 Facility ???ERROR: WrapperHyperV::failResultToStr: Last Error - The remote procedure call failed and did not execute.
(0x800706bf)
What can it be?
Fri Jul 25, 2025 3:45 pm
I think there could be an issue with the core itself. Can you please try converting the individual VM disk?
certinet
Fri Jul 25, 2025 4:12 pm
Converting to a VHD worked but I have couple of machines to convert. Would love to solve the issue connecting to Hyper-V
If I enter wrong credentials, I get Access Denied. If I enter good ones, stuck at Connecting Please wait
Fri Jul 25, 2025 4:53 pm
It looks like an issue relates to some missing libraries on the Hyper-V host.
Sadly, going disk-by-disk seems the workaround you need to stick with for now.
p.s. I have logged an internal testing request.
Fri Jul 25, 2025 4:55 pm
Can you please let me know the guest OS and see if VSS provider is working well?
certinet
Fri Jul 25, 2025 4:58 pm
Guest OS is Windows Microsoft Windows Server 2012 R2 Foundation. VSS works as we have Veeam backup running for that computer
Fri Jul 25, 2025 9:10 pm
Thanks for your update.
Can you try this converter https://drive.google.com/file/d/1hDP4gl ... Ea_5p/view?
certinet
Wed Sep 03, 2025 8:22 pm
Forgot to get back to you. Finally, I did a manual conversion and it all went good
Wed Sep 03, 2025 8:34 pm
Glad to read it ultimately worked :D
