V2V failed while create a snapshot
MauriceA
Tue Jul 08, 2025 12:42 pm
Hi All, trying to V2V from Vmware 5.1 to Hyper-V 2025. Can login, connection to Hyper V is successfull, but fails on creating snapshot.
The ESXi host was member of a vSphere cluster. But the vCenter server is broken. So I tried to do it directly from the host.
This needs to be done because het Vmware VM's needs to be removed van Vmware (hardware to old).
Below the logfiles created....
Kind Regards
Maurice
The log file name: 'logs\V2V_Log-20250708-125621.log' (PID 72752)
Delete log file 'logs\V2V_Log-20250407-103909.log'.
7/8 12:56:21.689 11d14 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/8 12:56:21.689 11d14 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
7/8 12:56:21.705 11d14 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/8 12:56:21.705 11d14 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/8 12:56:21.705 11d14 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
7/8 12:56:21.720 11d14 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 6d340000
7/8 12:57:01.736 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/8 12:58:19.893 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 12:58:20.893 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 12:58:20.893 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
"No connection could be made because the target machine actively refused it.
Detail: connect failed in tcp_connect()
7/8 12:58:20.893 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 12:58:26.065 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:09:41.564 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:09:42.595 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 13:09:42.595 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
7/8 13:09:42.595 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 13:09:48.157 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:10:02.892 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:10:03.908 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 13:10:03.908 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
7/8 13:10:03.908 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 13:10:07.908 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:10:17.361 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:10:18.376 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 13:10:18.376 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
7/8 13:10:18.376 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 13:10:22.720 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:13:02.612 11d14 Facility ???INFO: WrapperESXI::connect: m_url - https:***********
7/8 13:13:03.627 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 13:13:03.627 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
7/8 13:13:03.627 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 13:13:05.174 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:14:22.582 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:14:23.597 11d14 Facility ???ERROR: WrapperESXI::connect: m_proxy->RetrieveServiceContent fail - 28
7/8 13:14:23.597 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault SOAP-ENV:Server [no subcode]
7/8 13:14:23.597 11d14 Facility ???ERROR: VMConverter::ESXIConverter::Connection: connect fail - 28
7/8 13:14:25.222 11d14 Facility ???WARNING: CPPESXConnection::onNext: connect No connection could be made because the target machine actively refused it.
7/8 13:15:19.707 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:15:19.785 11d14 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - d0e346a2-1bb0-da29-7e68-a7a49298c8e0
7/8 13:15:19.785 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/8 13:15:20.051 11d14 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.1.0
7/8 13:16:30.739 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/8 13:16:32.302 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
7/8 13:17:09.990 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
7/8 13:19:17.148 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
7/8 13:20:19.789 111b0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
7/8 13:55:25.387 11d14 Facility ???INFO: CPPOutputFile::onNext: Out path: C:\RTM-TEST-01.vhdx, Out format 10
7/8 13:55:25.387 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
7/8 13:55:25.402 113b8 Facility ???INFO: CPPConverting::Convert: InConvertType: 5, OutConvertType: 4
7/8 13:55:25.418 113b8 Facility ???ERROR: WrapperESXI::createSnapshot: CreateSnapshot_USCORETask fail - 12
7/8 13:55:25.418 113b8 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
7/8 13:55:25.418 113b8 Facility ???ERROR: VMConverter::ESXIConverter::CreateSnapshot: createSnapshot fail - 12
7/8 13:55:25.418 113b8 Facility ???WARNING: CPPConverting::CreateSnapshot: Error creating snapshot - The session is not authenticated.
7/8 13:55:25.418 113b8 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Datastore04] ***********.vmdk, pathOutput: C:\RTM-TEST-01.vhdx
7/8 13:55:26.215 113b8 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore04] ***********.vmdk
7/8 13:55:26.215 113b8 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=506
7/8 13:55:26.215 113b8 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 8A:AC:ED:21:60:38:92:1B:27:F3:B5:19:42:C1:BE:E6:9C:47:CE:12
7/8 13:55:27.060 113b8 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/8 13:55:27.060 113b8 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/8 13:55:27.060 113b8 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/8 13:55:27.060 113b8 Facility ???ERROR: CPPConverting::Convert: FAILED
7/8 13:56:21.857 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocation
7/8 13:56:26.639 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/8 13:56:29.045 11d14 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
7/8 13:56:29.045 11d14 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
7/8 13:56:29.045 11d14 Facility ???INFO: WrapperESXI::connect: m_url - ***********
7/8 13:56:29.076 11d14 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - d34479bf-9423-ca04-aa1f-c054e3589827
7/8 13:56:29.076 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/8 13:56:29.311 11d14 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.1.0
7/8 13:56:34.920 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/8 13:56:40.779 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/8 14:00:32.704 11d14 Facility ???INFO: WrapperHyperV::connect: Host - ***********
7/8 14:00:55.939 11d14 Facility ???INFO: WrapperHyperV::connect: user: ***********
7/8 14:00:55.986 11d14 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ***********
7/8 14:00:56.001 11d14 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
7/8 14:00:56.001 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputVM
7/8 14:01:29.079 119d0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): Timeout ESX connection
7/8 14:02:50.892 11d14 Facility ???WARNING: ConfigNewHyperVVM::OnOK: The virtual machine path is empty.
7/8 14:02:51.736 11d14 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ***********
7/8 14:03:32.815 11d14 Facility ???WARNING: CPPOutputVM::OnButtonBrowseClick: Fill up GUID is fail
7/8 14:03:40.815 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
7/8 14:06:02.847 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
7/8 14:06:02.863 11d14 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ***********
7/8 14:06:38.191 11d14 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
7/8 14:06:38.191 1180c Facility ???INFO: CPPConverting::Convert: InConvertType: 5, OutConvertType: 7
7/8 14:16:29.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:30.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:31.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:32.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:33.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:34.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:35.072 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:35.807 1180c Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Datastore04] ***********.vmdk, pathOutput: **********************
7/8 14:16:35.807 1180c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore04]***********.vmdk
7/8 14:16:35.807 1180c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=506
7/8 14:16:35.822 1180c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 8A:AC:ED:21:60:38:92:1B:27:F3:B5:19:42:C1:BE:E6:9C:47:CE:12
7/8 14:16:36.463 1180c Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/8 14:16:36.463 1180c Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/8 14:16:36.463 1180c Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/8 14:16:39.526 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:41.526 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:45.526 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/8 14:16:53.526 1180c Facility ???INFO: WrapperESXI::Wait: Progress - 50
7/8 14:17:06.151 1180c Facility ???ERROR: CPPConverting::Convert: FAILED
Tue Jul 08, 2025 1:33 pm
Hi Maurice,
I don't think ESXi5 is still tested. Please consider shutting down the VM and converting the VM offline.
MauriceA
Wed Jul 09, 2025 6:31 am
Hi Yaroslav, thank you for your reply. Turned the vm off, but still not working.
The log file name: 'logs\V2V_Log-20250709-081139.log' (PID 67804)
Delete log file 'logs\V2V_Log-20250408-090937.log'.
7/9 8:11:39.354 11a50 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/9 8:11:39.354 11a50 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
7/9 8:11:39.354 11a50 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/9 8:11:39.354 11a50 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/9 8:11:39.369 11a50 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
7/9 8:11:39.369 11a50 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 6d340000
7/9 8:11:48.198 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/9 8:12:44.417 11a50 Facility ???INFO: WrapperESXI::connect: m_url - https://************/sdk
7/9 8:12:44.432 11a50 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - e6a61512-72b0-b54d-00ba-a83545189202
7/9 8:12:44.432 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/9 8:12:44.682 11a50 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.1.0
7/9 8:13:00.510 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/9 8:13:03.698 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/9 8:13:45.402 11a50 Facility ???INFO: WrapperHyperV::connect: Host - \\************\root\virtualization\v2
7/9 8:14:05.512 11a50 Facility ???INFO: WrapperHyperV::connect: user: ************
7/9 8:14:05.543 11a50 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ************
7/9 8:14:05.559 11a50 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
7/9 8:14:05.559 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputVM
7/9 8:14:37.715 11a50 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ************
7/9 8:14:54.137 11a50 Facility ???WARNING: CPPOutputVM::OnButtonBrowseClick: Fill up GUID is fail
7/9 8:14:59.043 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
7/9 8:15:04.950 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
7/9 8:15:04.965 11a50 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ************
7/9 8:15:12.434 11a50 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eOptionsHyperV
7/9 8:15:15.700 11a50 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eOutputVM
7/9 8:15:42.825 11a50 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ************
7/9 8:15:48.700 11a50 Facility ???WARNING: CPPOutputVM::OnButtonBrowseClick: Fill up GUID is fail
7/9 8:15:51.434 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
7/9 8:15:53.263 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
7/9 8:15:53.278 11a50 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: ************
7/9 8:15:55.247 11a50 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
7/9 8:15:55.263 1187c Facility ???INFO: CPPConverting::Convert: InConvertType: 5, OutConvertType: 7
7/9 8:15:55.263 1187c Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Datastore04] RTM-TEST-01/RTM-TEST-01.vmdk, pathOutput: C:\ClusterStorage\Volume1\RTM-TEST-01\Virtual Hard Disks\RTM-TEST-01.vhdx
7/9 8:15:55.559 1187c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore04] RTM-TEST-01/RTM-TEST-01.vmdk
7/9 8:15:55.559 1187c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=506
7/9 8:15:55.575 1187c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 8A:AC:ED:21:60:38:92:1B:27:F3:B5:19:42:C1:BE:E6:9C:47:CE:12
7/9 8:15:56.247 1187c Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/9 8:15:56.247 1187c Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/9 8:15:56.247 1187c Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/9 8:15:56.247 1187c Facility ???ERROR: CPPConverting::Convert: FAILED
Wed Jul 09, 2025 9:14 pm
Could you please convert an individual disk?
MauriceA
Thu Jul 10, 2025 7:02 am
When i download the vm from the datastore and do a conversion this works well. Machine is created in Hyper V.
When i do just one disk the same issue exists.
Think it is a permissions problem or something like that.
Because the server is refusing connection. I think it is the ESXi server, or the Datastore.
7/10 8:23:48.328 1269c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore04] RTM-TEST-01/RTM-TEST-01.vmdk
7/10 8:23:48.328 1269c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=59
7/10 8:23:48.344 1269c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - D9:9A:88:E6:BE:CC:22:9F:2D:66:68:CD:37:54:FE:59:87:FD:E4:3A
7/10 8:23:48.969 1269c Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/10 8:23:48.969 1269c Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/10 8:23:48.969 1269c Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/10 8:38:51.633 1269c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/10 8:38:53.633 1269c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/10 8:38:57.633 1269c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/10 8:39:05.633 1269c Facility ???INFO: WrapperESXI::Wait: Progress - 0
7/10 8:39:21.633 1269c Facility ???INFO: WrapperESXI::Wait: Progress - 50
7/10 8:39:34.071 1269c Facility ???ERROR: CPPConverting::Convert: FAILED
7/10 8:43:48.324 125f8 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
Thu Jul 10, 2025 7:04 am
If Free version is used, it could be a licensing limitation too.
