Connection to Proxmox Host not possible
HHR_NC
Wed Jun 11, 2025 9:31 am
I am trying to use the V2V Converter to convert a Proxmox VM to Hper-V, but I can´t connect to the Proxmox Host. The error I get is "The Host name or credentials are wrong!" although I am 100% suer they are not. SSH and GUI login with the same credentials works. The logs show the following:
6/11 11:26:54.325 2ff4 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Connect to Proxmox host
6/11 11:26:54.325 2ff4 Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetHostVersion: Get proxmox host version info
6/11 11:27:00.341 2ff4 Facility ???ERROR: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Failed to parse JSON response
I am using Proxmox version 8.3.0.
Wed Jun 11, 2025 10:02 am
Could you please share the entire conversion log?
HHR_NC
Wed Jun 11, 2025 10:11 am
Hi, here is the entire log:
6/11 12:07:31.021 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
6/11 12:07:31.021 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.755
6/11 12:07:31.025 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
6/11 12:07:31.025 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
6/11 12:07:31.027 2de8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 14393
6/11 12:07:31.029 2de8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 47350000
6/11 12:07:31.030 2de8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 47350000
6/11 12:08:32.715 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - (null)
6/11 12:09:23.518 259c Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Connect to Proxmox host
6/11 12:09:23.518 259c Facility ???INFO: Proxmox::WrapperProxmox::WrapperProxmoxImpl::GetHostVersion: Get proxmox host version info
6/11 12:09:29.551 259c Facility ???ERROR: Proxmox::WrapperProxmox::WrapperProxmoxImpl::Connect: Failed to parse JSON response
thank you for the fast response!
Wed Jun 11, 2025 1:40 pm
There is an issue with connecting to the Proxmox host.
Try copying the files to the Hyper-V host > convert them locally > and assemble the VM. Or convert to OVF templates.
