VirtualBox .VDI incorrect header
userman
Sun May 18, 2025 9:48 am
Hi
I don't know if it's intentional or a typo, but the program creates a slightly "crooked" VDI, namely with the name in header:
<<<< Oracle VM VirtualBox Disk Image
the standard one looks like this:
<<< Oracle VM VirtualBox Disk Image >>>
this title is informational, and it doesn't seem to affect the work of other programs...
Sun May 18, 2025 1:01 pm
Thanks for your update. Could you please describe the conversion scenario? I will need the source Hypervisor and whether you are trying to convert the entire VM as V2V?
Aliyaueller
Mon May 19, 2025 6:42 am
It is possible that each program was run differently and therefore some structures were changed to accommodate. This information is too limited for me to determine further.
Mon May 19, 2025 6:48 am
Excuse me, I don't follow your comment, please rephrase.
userman
Mon May 19, 2025 12:11 pm
I use local conversion VHD, VHDX to VDI
Mon May 19, 2025 12:25 pm
Thanks for your update! What is the source hypervisor (e.g., Windows Server 2022)? Do you convert the entire VM or just its disks?
userman
Mon May 19, 2025 12:34 pm
It was a disk created using standard tools Windows 11
Mon May 19, 2025 1:27 pm
Thanks! I have logged a request.
Thanks for pointing that out.
Mon May 19, 2025 2:48 pm
That's expected: my colleague mentioned that Virtual Box adds these headers.
userman
Mon May 19, 2025 3:38 pm
Virtual Box add header:
but V2V Converter add header:
Mon May 19, 2025 5:54 pm
I will ask my colleagues to look at that [again]. Thanks.
Tue May 20, 2025 4:40 pm
You are absolutely right: it was a typo. Thanks for your cooperation.
userman
Wed May 21, 2025 3:11 am
Дякую і вам
