Incorrect file type identifiers in online command line documentation
Spoza
Mon Apr 28, 2025 8:42 pm
I registered only to let you know that the online documentation at https://www.starwindsoftware.com/v2v-he ... rface.html is wrong / outdated...
The documented file type identifiers say "_thin" and "_thick" suffixes, but these are rejected by the V2V console application.
The correct suffixes are "_growable" and "_pre_allocated", as the V2V console application help text correctly says...
Tue Apr 29, 2025 12:25 am
Thanks for your input! We are working on redoing that part. Many thanks!
riertiz
Mon May 05, 2025 1:57 pm
You might consider suggesting they sync the web documentation with the actual application help output.
