Stuck trying to import ESXi VM's
saron
Fri Feb 21, 2025 3:09 pm
I am trying to import ESXi VM's from a remote machine to the local Hyper-V, everything goes as expected until I reach the step 'Check settings of the new virtual machine'. I need to select a local path (tried several), a name and OS type. But when I press 'Convert' nothing happens, and the logs says: Facility ???ERROR: CPPVMSettingsHyperV::onNext: OS disk not found
There is a 'Select OS disk' field but it is disabled.
Also the 'Network connection' is disabled.
This is a new Hyper-V setup (on Windows Server 2022 Standard) with nothing existing in Hyper-V yet.
Am I missing something? I there a bug? Using StarWind V2V Converter v9.0.1.623
Fri Feb 21, 2025 4:15 pm
Welcome to StarWind forum.
Please convert it as a local disk without attaching that disk to a VM.
