V2V - RHEL 8.6 vmdk to qcow2
n_bhaskara
Thu Feb 13, 2025 11:33 am
Greetings!
I am trying to convert a RHEL8.6 VM (vmdk) to a qcow2 image using the "Local file" option and it gets converted successfully. However, when i import the qcow2 in Ubuntu 22.04 KVM hypervisor using virt-manager, the VM fails to boot and goes to recovery.
The VM starts booting and fails to identify the root disk as seen on the console. Below is the error message:
dracut warning: /dev/mapper/root does not exist
dracut warning: /dev/rhel/root does not exist
dracut warning: /dev/rhel/swap does not exist
When i mount the qcow2 image on the kvm hypervisor, i am able to see the partitions and there are no errors reported on the qcow2 image.
Has anyone tried this earlier?
Thank you!
regards,
Bhaskar
Thu Feb 13, 2025 12:10 pm
Welcome to StarWind Forum. It looks like some drivers are messing things up.
Check this out https://forums.starwindsoftware.com/vie ... HEL#p38244.
n_bhaskara
Thu Feb 13, 2025 4:21 pm
Hello!
Thank you for the reply and yes it's a driver issue. Issue is resolved now.
regards,
Bhaskar
Thu Feb 13, 2025 5:06 pm
Thanks for your update!
