physical drive to vmdk
fpefpe
Mon Dec 02, 2024 6:16 am
Hello --- I just converted a 2tb drive to a vmdk -- the drive was about 50% full --- vmdk file is around 800gb -- when go to mount it, the partition is incorrect is there a way to debug this
Mon Dec 02, 2024 6:33 am
Welcome to StarWind Forum. What is the source disk (dynamic or fixed) and destination?
fpefpe
Mon Dec 02, 2024 7:16 am
The source is fixed via USB connection the target is a local vmdk file that grows to size as needed
Mon Dec 02, 2024 7:44 am
Great, thanks for letting me know.
fpefpe
Mon Dec 02, 2024 1:38 pm
thanks for your reply --- I have a screen shot of the drive in the disk manager if you need to see what this look like
Mon Dec 02, 2024 3:44 pm
Just to be clear: are you converting a USB volume to a virtual one? What is the output disk? Is it fixed or dynamic?
fpefpe
Mon Dec 02, 2024 4:07 pm
yes this is a usb attached fixed drive 1 primary partition with a ntfs file system converting to a vmdk growable drive ---
here is a link to a screen shot of the disk manager --- disk4 is source and disk4 and disk6 is the mounted vmdk file
https://u.pcloud.link/publink/show?code ... MN5SLo3CR7
Mon Dec 02, 2024 6:32 pm
Try converting that USB to a fixed drive.
fpefpe
Mon Dec 02, 2024 7:01 pm
not sure what you mean by "fixed drive" the end result has to be a vmdk file --- do you mean that the drive should be connected to the computer sata interface?
Mon Dec 02, 2024 7:17 pm
There are 2 conversion options: growable (dynamic) and fixed. See more at https://community.spiceworks.com/t/what ... 6/553727/2
fpefpe
Mon Dec 02, 2024 7:47 pm
I don't think my target drive has 2tb free l will have look at that
Mon Dec 02, 2024 9:22 pm
No worries.
Could you please let me know if you have access to your data on that 800 GB device?
fpefpe
Mon Dec 02, 2024 9:43 pm
No if you look at the link there are 4 partitions that map to junk windows does not even a sign a drive letter
Mon Dec 02, 2024 10:15 pm
Could you please share the conversion logs with me?
fpefpe
Mon Dec 02, 2024 11:24 pm
where are the logs saved?
