Post migration issue with VEEAM
ShaneP
Thu Nov 07, 2024 10:28 pm
A contractor has P2Ved some servers for me but the disks are showing as MVMDK in the folders on storage. VEEAM is having issues because it wants VMDK not MVMDK. Is there a simple way to convert the files back to VMDK? Do I need to run a V2V or something?
Thu Nov 07, 2024 10:53 pm
Welcome to StarWind Forum. StarWind does not allow conversion to MVMDK (see more on supported formats here https://www.starwindsoftware.com/v2v-he ... tions.html). Can I please have the conversion logs?
ShaneP
Sun Nov 10, 2024 10:47 pm
Thanks. Logs are zipped and attached
V2V_Log-20240731-154300.zip
(1.73 KiB) Downloaded 440 times
Tue Nov 12, 2024 3:51 am
Many thanks!
I can see that you use the previous version of V2V. Could you please check if the latest one also converts the file to mvmdk in your system?
Berthauber
Wed Nov 13, 2024 4:48 am
You can try using VMware's vmkfstools command to convert the MVMDK files back to VMDK format. You don't necessarily need a full V2V conversion, just a simple disk format conversion should work.
Wed Nov 13, 2024 9:11 am
Good point.
