Dreaded access is denied error
pickledsanguine
Tue Oct 01, 2024 9:03 pm
Hello.
I'm trying to do a P2V from a Windows Server 2008 R2 physical host to a Windows Server 2019 Hyper-V host.
Whenever I try to connect, I get this error:
Access is denied 0x80070005
I know the 0x error is a DCOM error so I checked that and confirmed that all settings for the DCOM are where they should be -- I even turned them down a bit but the error persists.
I added the Admnistrator user to the DCOM group in lusrmgr.msc as well as to Hyper-V and other admin groups but the issue persists.
I created a new account and gave it all the needed admin groups but the issue persists.
I confirmed that the C$ share is accessible from the 2008 host.
I've confirmed that all Hyper-V features are currently installed.
I'm really stuck on where else to proceed.
Here is the log from today's attempts:
I wanted to post the log but apparently I can't since it says that it "Contacts contacts."
Here's the important part:
10/1 15:25:31.304 1318 Facility ???INFO: WrapperHyperV::connect: Host - \\hyperv-1\root\virtualization\v2
10/1 15:25:31.380 1318 Facility ???ERROR: WrapperHyperV::connect: pLoc->ConnectServer \\hyperv-1\root\virtualization\v2 - 0x80070005
10/1 15:25:31.380 1318 Facility ???ERROR: WrapperHyperV::failResultToStr: Last Error - Access is denied.
(0x80070005)
Fri Oct 04, 2024 5:14 pm
HI,
Make sure the user has the read/write privileges for that share.
tonyaljohnson
Fri Feb 07, 2025 3:15 am
The “access denied” error can be quite annoying, especially when migrating from an older server to a newer one. To quickly fix this error, make sure that the user has the necessary read/write permissions for the shared folder and double-check all DCOM configurations to ensure they are set up correctly.
Fri Feb 07, 2025 8:24 am
Arielbr
Tue May 27, 2025 7:37 am
Thank you very much for these detailed instructions, I will check the access rights and DCOM configuration right away to fix the “access denied” error.
Tue May 27, 2025 7:51 am
You are welcome!
Make sure you have CredSSP on both nodes.
What also helps is a failover cluster as a domain admin on the cluster nodes themselves.
If nothing helps, redeploy might be needed.
