No mouse cursot after migrating.
ipod86
Fri Aug 02, 2024 11:13 am
I moved 2 physical PCs to an ESXi using the StarWind V2V Converter, P2V Migrator.
Some PCs can also be booted in ESXi.
However, I can't get a mouse cursor to control anything via RDP or in the remote console in the ESXI.
Fri Aug 02, 2024 11:39 am
You need to install VMware tools.
ipod86
Fri Aug 02, 2024 1:20 pm
How can I do that without a mouse?
When I start the setup via Esxi it doesn't work.
Fri Aug 02, 2024 1:34 pm
Try using the keyboard.
This could be also helpful https://www.petenetlive.com/KB/Article/0001370.
ipod86
Sat Aug 03, 2024 8:27 am
Thanks for the answer.
I still have 2 questions.
Can I install the VMware Tools on the bare metal beforehand or will that affect further operation on the physical machine?
So far I have used the VMware vCenter Converter and have not had any problems. Does it integrate the tools when converting?
Sat Aug 03, 2024 9:05 am
Greetings,
Theoretically, yes you can install it. I believe it is more a VMware-related question. Could you please let me know the OS you use inside that VM?
No, it does not. VMware tools are to be installed after conversion.
ipod86
Sat Aug 03, 2024 9:12 am
I tested a Win10 and Win11 computer. With the VMware vCenter Converter, only the Win10 computer where the mouse worked.
Sat Aug 03, 2024 9:39 am
Guess there's something on the VMware tools side.
As a workaround, try converting individual disks.
