VMWare to HyperV
DavidMcQueenLPS
Wed Jul 10, 2024 4:43 pm
HyperV 2022
ESXi Host 8.0.1
vSphere 8
Have tried both ESXi and vSphere connections and I get a "ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection" error everytime. I know the connection to VMWare is fine, as I get the list of Guests to choose from to convert. I also know that the connection to the HyperV host is good as I can choose the destination path.
I know that I can manually "Export" the Guest from the vSphere interface and then convert using Local File VDMK, but I have 10 hosts and 500+ guests to do. I would like to be able to set it and forget it.
Here is the log file for an attempt connecting to the ESXi Host:
The log file name: 'logs\V2V_Log-20240710-120559.log' (PID 4828)
7/10 12:05:59.013 23dc Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/10 12:05:59.013 23dc Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
7/10 12:05:59.029 23dc Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/10 12:05:59.029 23dc Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/10 12:05:59.029 23dc Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
7/10 12:05:59.029 23dc Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - fc450000
7/10 12:06:02.529 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/10 12:06:12.388 23dc Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.1.50/sdk
7/10 12:06:12.419 23dc Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 9440df63-e4dc-afae-1ef5-a38476959d4b
7/10 12:06:12.419 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/10 12:06:12.638 23dc Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.1
7/10 12:06:37.846 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/10 12:06:40.416 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/10 12:06:49.794 23dc Facility ???INFO: WrapperHyperV::connect: Host - \\hyperv\root\virtualization\v2
7/10 12:06:50.028 23dc Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
7/10 12:06:50.028 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
7/10 12:06:55.763 23dc Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
7/10 12:06:55.778 1f10 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
7/10 12:06:55.778 1f10 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Datastore1] SHER-HWell-VDI/SHER-HWell-VDI.vmdk, pathOutput: D:\HyperV-VMs\SHER-HWell-VDI\Virtual Hard Disks\SHER-HWell-VD.vhdx
7/10 12:06:55.841 1f10 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore1] SHER-HWell-VDI/SHER-HWell-VDI.vmdk
7/10 12:06:55.841 1f10 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=198
7/10 12:06:55.841 1f10 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 40:0F:17:94:5C:AC:AF:31:03:1B:8E:6A:34:01:93:80:5D:A8:8B:22
7/10 12:07:38.126 1f10 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/10 12:07:38.126 1f10 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/10 12:07:38.126 1f10 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/10 12:07:38.126 1f10 Facility ???ERROR: CPPConverting::Convert: FAILED
7/10 12:09:07.312 29cc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
Here is the Log when connecting to vSphere:
The log file name: 'logs\V2V_Log-20240710-123142.log' (PID 8200)
7/10 12:31:42.841 fd0 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
7/10 12:31:42.841 fd0 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
7/10 12:31:42.841 fd0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
7/10 12:31:42.841 fd0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
7/10 12:31:42.841 fd0 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
7/10 12:31:42.856 fd0 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - fc450000
7/10 12:31:46.679 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
7/10 12:32:15.006 fd0 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.1.5/sdk
7/10 12:32:15.116 fd0 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 6523485b-ecf2-d48f-3259-2bdfe6a15f9f
7/10 12:32:15.116 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
7/10 12:32:24.452 fd0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.1
7/10 12:32:24.452 fd0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.1
7/10 12:32:24.452 fd0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
7/10 12:32:24.452 fd0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.2
7/10 12:32:33.100 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
7/10 12:32:39.899 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
7/10 12:32:51.850 fd0 Facility ???INFO: WrapperHyperV::connect: Host - \\hyperv\root\virtualization\v2
7/10 12:32:51.975 fd0 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.20348
7/10 12:32:51.975 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
7/10 12:32:59.710 fd0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
7/10 12:32:59.723 1044 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
7/10 12:32:59.723 1044 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [Datastore1] SHER-HWell-VDI/SHER-HWell-VDI.vmdk, pathOutput: D:\HyperV-VMs\SHER-HWell-VDI\Virtual Hard Disks\SHER-HWell-VD.vhdx
7/10 12:32:59.787 1044 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Datastore1] SHER-HWell-VDI/SHER-HWell-VDI.vmdk
7/10 12:32:59.787 1044 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-659189
7/10 12:32:59.803 1044 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 62:92:F1:01:BA:33:75:DF:0E:55:AF:C6:48:15:39:95:7B:56:9F:31
7/10 12:33:42.143 1044 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
7/10 12:33:42.143 1044 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
7/10 12:33:42.143 1044 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 1
7/10 12:33:42.143 1044 Facility ???ERROR: CPPConverting::Convert: FAILED
7/10 12:33:47.131 8b0 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
Fri Jul 12, 2024 11:23 am
Welcome to StarWind forum. Make sure the following ports are opened
443 TCP,UDP
902 TCP,UDP VMware Infrastructure Client/VMware Server Console
